Funny, I just had the same problem. I have the same problem. I have tried to refresh and heal the node a couple of times, but no solution. What parameters are you planning to set?
It seems like the Oomis are missing configuration files in the github library you are linking to. I have the same problem with the wallmote from Oomi, but I have found a workaround. I have stopped the homeassistant service and then added the missing configuration in the zwcfg_****.xml file. I found the a thread in for the wallmote here Aeotec wallmote quad zw130.
I have the aeotec version of the same sensor and that works fine.
after adding the details from “manufacturer_specific.xml” it seems to work now, but I can’t update the “Node config options” this ist the log output.
After setting the parameter “Temperature Reporting Threshold” to “20”, the parameter reverts back to “5121”
here’s the log snip: https://pastebin.com/CVvPvTW7
sometimes I can see the following: "Unhandled Command Class 0x20"
don’t know if that’s related to the issue
I gave up and bought the Aeotec Multisensor 6. This thing works out of the box for now.
Returned the Oomi Multisensor.
Update:
The new Aeotec Multisensor 6 working fine out of the box. Just before I returned the Oomi Sensors I flashed my Aeotec Multisensor 6 with the newest firmware and I thought if they are both the same, why not try to flash the Aeotec Multisensor 6 to the Oomi Multisensor 6.
And guess what, flashing the newest Aeotec firmware to the Oomi sensor works fine and after a reset, it appears as a Aeotec Multisensor 6
no need to struggle with zwave configs and logs, just flash the device with the current firmware and the Aeotec tool from Aeotec homepage.
