I have an OOMI home kit also known as Fantem and Aeotec.
How can I integrate these devices / system into Home Assistant?
I tried to add them / search for them in “Z-Wave JS” but no luck
I’m using a Nortek USB.
Any help will be appreciated.
Are these Z-Wave hubs??
You list brand names with no other useful information. That is like someone saying they drive a Ford while not stating it is a diesel tractor…
I know that works with zwavejs
The device database is here It lists 14 Fantem device entries.
I thought I added more info my bad.
I have the starter kit with their tablet, cube, bulbs, smart wall plugs, door sensors and motion sensor. (I can probably get some models number if needed when I get back home).
The tablet and cub are the hub for the system and they use NFC to add devices to them.
Similar to this but I think mine is the original (in white).
Thanks for the link I will try again tonight to see if I can get it going.
Do I have to add those files you linked manually or are they included in the zwave js installation?
Thanks.
There does not appear to be an official integration for the OOMI
hub.
They are included in the installation.
Thanks for the replies, really appreciate it.
If they’re included then there must be something wrong with my zwave setup.
I’m using a Nortek USB stick.
Will fiddle around with it more.
Does this mean that the USB is working but I’m unable to add the devices?
And what does the device disconnects?
Thanks again.
2021-06-07T15:00:29.696Z CNTRLR starting inclusion process…
2021-06-07T15:00:29.705Z CNTRLR handling add node request (status = Ready)
2021-06-07T15:00:29.705Z CNTRLR the controller is now ready to add nodes
2021-06-07T15:01:59.695Z CNTRLR stopping inclusion process…
2021-06-07T15:01:59.754Z CNTRLR handling add node request (status = Done)
2021-06-07T15:01:59.754Z CNTRLR done called for 0
2021-06-07T15:01:59.754Z CNTRLR the inclusion process was stopped
Client disconnected
Code 1000:
New client
New client
Client disconnected
Code 1000:
2021-06-07T15:03:42.328Z CNTRLR starting inclusion process…
2021-06-07T15:03:42.337Z CNTRLR handling add node request (status = Ready)
2021-06-07T15:03:42.337Z CNTRLR the controller is now ready to add nodes
2021-06-07T15:04:42.089Z CNTRLR stopping inclusion process…
2021-06-07T15:04:42.148Z CNTRLR handling add node request (status = Done)
2021-06-07T15:04:42.148Z CNTRLR done called for 0
2021-06-07T15:04:42.148Z CNTRLR the inclusion process was stopped
It appears you are using zwavejs
. Have you looked at their documentation and followed their troubleshooting recommendations? They handle support requests on GitHub.
I was on that page earlier.
I tried using “Z-Wave JS” and “Z-Wave JS to MQTT” still no luck.
I will head over to github and see what I can find.
Thanks.
You might want to start a discussion here.
