I deleted a database file from my HA config folder as I had moved over to MySQL, but I am guessing that HA had stored my new user credentials in there as it is now broken. I can’t log in anymore with the two users I set up (Including the admin/owner). I am still able to log in with the legacy API password that I had also enabled.
I tried to run the script that was released a few releases ago when the new user system was first previewed, but I’m running HA on Docker and I can’t work out if it’s even possible to run it under docker (the hass command doesn’t work in the docker CLI).
Anyone have any idea how I can re-create my main user and get back up and running?
Unfortunately that doesn’t work. I think (currently) only the first/master user can add new users. I just get the error “unauthorized” when I try and add.
Same problem here. If I remove “.storage” folder, the folder and the auth file is recreated (after I login with my legacy API password again), guess it gets it from the MariaDB database?
Same problem here. I can login with Legacy API Password and I can’t create any user. When I delete the folder “storage”, it is recreated with “auth” file in it.
Any suggestion?
Thank you!
