Open a listening port in Node-Red add-on?
Hello. I’m trying to setup a TCP-In listening node in the Node-Red addon that I can use to trigger automations in Home Assistant.
Setting up the TCP-In node is straight forward enough, however I think I need to open the listening port on the Add-On container in order for other devices to be able to connect to it. Is there a way to do this? In the configuration section of the Add-On there is a “Network” section for exposing ports, but it only appears to allow editing the port that the Node-Red Web Interface can use.
Can this be done? Thanks for any help.
Node-Red is configured for host networking, which means that any port that the container starts listening on should be available on the host.
You are correct, thank you! I assumed since the web interface port was being remapped that ports were mapped. All is working now. Thanks.
Hello I also use node red to listen traffic from TCP in but I got regular disconnects (it the reconnects after some time). Same with the command I send via TCP out.
Am i the only one ? If not have you been able to solve this ?
