I am new to the world of Home Assistant and I want to know your opinion before buying stuff that I don’t need.
My plan is to have 4 blinds that open and close with their own switch and a different switch to control them all. The system should work without the need of internet or WiFi.
I already have Raspberry Pi 4 with home assistant and I need a ZigBee USB dongle, should I be worried about any particular problem for the configuration?
Then I need to install 4 ZigBee curtain actuators and I was thinking about Tuya or Moes (do you suggest one in particular?) that should work fine with Home Assistant.
https://it.aliexpress.com/item/1005007010573203.html
The problem is now to create a trigger to open all the blind at once. I have a physical wall mounted switch (with the possibility of pushing and keeping pushed the upper and lower button and to release them) not linked with anything (no wires) that need to communicate with Home Assistant, what is the best way to achieve this? Do I need another ZigBee actuator (of course not linked with any motor)? Do I need a smart switch? In this case it is able to detect whether the upper/lower button is pressed and released?
A smart switch like this could be fine?
https://it.aliexpress.com/item/1005003678777697.html
Thanks in advance for your help!
