Hi, your suggestion/s please:
My set-up includes Xiaomi Remote Control + integrated RF433mhz which do not report open, close or position state.
I have created 3 RF actions (To send RF signal to open, close or pause the blinds in my study room) in script.yaml file as below:
studyroom_blinds_close:
alias: Studyroom Blinds Close
sequence:
- data:
command:
- raw:XXXX
entity_id: remote.livingroom_ir_controller
service: remote.send_command
studyroom_blinds_open:
alias: Studyroom Blinds Open
sequence:
- data:
command:
- raw:XXXX
studyroom_blinds_pause:
alias: Studyroom Blinds Pause
sequence:
- data:
command:
- raw:XXX
Yes, I do not need the ‘state’ status to be remembered and basically just one way sending the RF command to the device; I want the device can be called open or close or paused and it will execute.
I created template as below so that i can control it with the UI in HA or Google assistant to control.
cover:
covers:
stuyroom_blinds:
friendly_name: "Studyroom Blinds"
# I am not sure what should be defined in the value_template to remain the status out of open, close or pause
value_template: "{{ true }}"
open_cover:
service: script.studyroom_blinds_close
close_cover:
service: script.studyroom_blinds_open
stop_cover:
service: script.studyroom_blinds_pause
I mainly use Google Assistant or the UI and with the current setting above, the state will stay “true” and i am not able to contro. Is there a way I can activate all 3 buttons in the UI for cover template? Appreciate any suggestion or guidance.
Thanks,
Terence
