Open Hardware monitor sensors
I set up the Open Hardware Monitor component to monitor my server with Home Assistant. When my server is off and I restart Home Assistant my sensors disapear and do not pop up after I boot up the server.
Is there a way to force the component to rescan for available entities?
Not with the current Implementation.
I saw on the github page you are one of the contributers. I wan’t to make a feature request for a “optimistic” mode that will create the entities if the server is not available and the option to declare what sensors from OHM I want to monitor.
Where can I submit a feature request?
In this forum category: https://community.home-assistant.io/c/feature-requests
Thank you! I tought I had to make a feature request on the github page.
