All power comes from the JST connectors for each board. The kit comes with a connector and pigtail, but I bought crimp pins and shells and made my own harnesses so I could run them all directly to my fuse panel in the lower right area.
From Digikey:
The board power in shell is:
XHP-4
CONN RCPT HSG 4POS 2.50MM
The sockets are:
SXH-001T-P0.6N
CONN SOCKET 22-26AWG CRIMP TIN
I also extended the LORA and cellular antenna coax with:
135101-01-M2.00
CBL ASSY SMA PLUG TO PLUG 6.6’
And:
ADP-SMAF-SMAF-B-G
CONN ADAPT JACK-JACK SMA 50 OHM
The power supply out connector shell is:
VHR-6N
CONN RCPT HSG 6POS 3.96MM
The power supply in connector shell is:
VHR-3N
CONN RCPT HSG 3POS 3.96MM
The power supply sockets are:
SVH-41T-P1.1
CONN SOCKET 16-20AWG CRIMP TIN
I used 16awg wire and cut a lamp cord for AC in.
The power supply was bought from eBay under this title…. Way cheaper than Amazon:
1pcs MEAN WELL Security Power Supply PSC-60A-C PSC-60B-C
The RS-485 terminals need twisted pairs, so I used cat6 cable and pulled out a twisted pair. The power for the RS-485 devices must be isolated from the incoming power. I used 20awg wire with ferrules but cat6 would have worked fine.
I have invited the creator of this equipment to the forum as I think he will be able to answer questions publicly (to help others) and also get feedback as he is adding features useful in HA.
Hello Jack,
thanks for sharing :), and btw, very nice setup. The DIN terminal blocks bring nice touch to wiring and over all cleanness. I really like it.
Also, for simple door contacts, I need to change the zone to be “Unballanced” and then connect one wire to the zone 12v and the other to the zone input…. Correct?
Ok, so connect zone terminal through the door sensor to GND? Correct?
Thanks!
For everyone else reading this, Adam made me a new branch of firmware because I wanted the capability of connecting 50 zones. He did not have to do that, but I really appreciate the rapid support and update just to get me what I needed.
Adam, I see a lot of action on GitHub showing updates. Are any of them for my branch with the 50 zones?
For the new versions, the Home Assistant MQTT Automatic Discovery in now fully done and implemented. Also with a new MQTT topic called /alert, where any of the existing alters can be propagated to HA. For example there are action like key actions, armed, disarmed, unknown. AC and battery states. Zone open, alarm or tamper states.
Your branch is not touched yet. I think we need to discuss how to produce binary for your special configuration. Since normally binary is being built from master branch by GitHub Actions, there is a whole build environment in my other repository. Maybe you can make a fork of my repo, merge my master and let the Actions to build a binary for you?
I created a fork of your whole repository. I am not too familiar with GitHub so I may need some help making sure I do what you are say. Do you mind stepping me through this? I have friends that use GitHub and can help but they were not sure where everything is that you are asking me to use.
Then I guess you need to install git command line tool, and do merge of master branch to multi-extensions branch.
After that you modify the .github/workflows/compile_and_build.yml file and add multi-extensions to these statements:
add branches: [ main, master ]
Then you just push to GitHub, and wait for the GitHub to build it.
Most work will be to decide what to merge. For you the most important is to keep following in ohs_conf.h
#define ALARM_ZONES 56 // # of zones
#define MQTT_FIFO_SIZE 80 // To accommodate various sources like zones, groups, sensors
Yes branches: [ main, master, multi-extensions ]
then the build will run also on multi-extensions, or better yet, you can actually remove the main, master, so it will be build only on your branch.
Sorry for the late response. I was out of town for work.
I think I did it right. Can you see my fork and tell if it is done right?
All,
Just got a SIM card in from Red Pocket. I checked their tech support hotline and they say the IMEI is compatible with their plans. It was. $30 per year with 1000 sms per month. Should be enough.
