This morning it started working again and the predictions are much closer to those by SolCast. For today the forecasts differ by 3.2kWh (Solcast: 52.5kWh), for tomorrow by 13.2kWh (Solcast: 98.3kWh) - in both cases Open Meteo is still underestimating.
Tried that here for my setup, but without the cloud data from Open-Meteo, it overestimates extremely (almost double) for me. The previous version with the cloud data worked just fine.
Thanks, I’ve also noticed that the cloud cover compensation code seemed to work fine for me. I just need to figure out how to best make use of it and when to trigger it.
I’ll see what I could do about this. Personally I like the Kasten-Czeplak model because it’s simple and effective (works really well when you’re using clear sky approximation), but the biggest issue is that Open-Meteo sometimes accounts for cloud cover properly and having Open-Meteo’s compensation interacting with my own causes massive underestimation.
It’s pretty interesting that people seem to be interested in this
I’ve been watching the forecast for a few days and it worked fine together with the cloud data. Not perfect, not 100%, but we must not forget that it is a forecast and that it is based on other forecast data. That makes it impossible to be 100% accurate.
Also, some regional weather conditions make things complicated. Therefore, I don’t think it’s a good idea to change or adjust the calculation immediately in case of deviations. Instead, you should observe the whole thing over a longer period of time. If you expect a 100% production forecast, you should realise that the weather data required for this is never 100% accurate. Forecasts are forecasts, sometimes they can be like looking into a crystal ball. This also applies to SolCast and other services. Sometimes one is better, sometimes the other …
Thanks, that’s my mindset as well but it seems pretty bad for it to be off by that much so I was more willing to revert it. I’ll come up with something more suitable maybe in the weekends, I have some ideas. This is just a side project for me (obviously).
Of course, this is FOSS so you could contribute as well if you have some ideas on how to best approach this issue.
I think the original approach, which took cloud density into account, was very good and I currently see no need to improve or change the whole thing in any other way.
I looked at the cloud data provided by Open-Meteo and ran a few tests myself. Perhaps the mid and low cloud density should somehow be put in relation to each other, or perhaps an average value should be calculated from both and then used to calculate the production. But I haven’t tested that yet, it’s just an idea …
It would be helpful to have more information about which cloud cover at which altitude has the greatest influence on production. Then you could play around with the different data from different altitudes …
I have forgotten one thing that has not made sense to me so far: the efficiency_factor in the calculation is not particularly clear to me, especially when to adjust it and in which direction … ??? Is there any information here?
I’ve tried to account for cloud low and mid before in my experimentation and I found that using mid or high leads to results that are too pessimistic. What I ended up doing was averaging the two values and taking the maximum of the two, both approaches were too pessimistic and there was never an instance where it worked well.
Only taking cloud low worked okayish in my case, and I think it could very well be dependent on location (i.e., available solar radiation data) which is why it seems to be working poorly for some.
You could possibly include the Open-Meteo sunshine_duration value. All radiation above 120 W/m2 is considered sunshine there. So if we have a high cloud density, but at the same time a high sunshine duration, then a reduction in the cloud density might make sense. However, it is unclear to me how this can be mathematically correlated.
I’d assume that the sunshine duration is reflected in the average radiation that Open-Meteo returns, so it didn’t seem worth investigating but I might be wrong.
That is true, but shouldn’t the cloud cover values then also be part of the calculation of the Open-Meteo irradiation values?
Actually, that should be the case, so that the cloud cover could be ignored for the production forecast. But this then leads (at least for me) to exorbitant forecast values and only the consideration of the cloudiness values brings the whole thing back to normal values (which might be a simple coincidence, though)
If I look at a graph on Open-Meteo with all the available cloud cover values for the current day, as well as the radiation values, then I can’t see any connection, i.e. I don’t see any higher radiation values with lower cloud cover, the curves don’t seem to be connected to each other … that doesn’t make the whole thing easy
