Thanks for your work on this integration. Mine is still underestimating when comparing to solcast. I’m using the recommended 0.93 effeciency factor
Solcast
Forecast Today 35.83 kWh
Forecast Tomorrow 34.05 kWh
vs Meteo
Estimated energy production - today 25.8 kWh
Estimated energy production - tomorrow 25 kWh
What’s your setup like? Do you have multiple solar panels configured in the integration?
Edit:
Also note that the azimuth in this integration vs solcast is different for when it is <0 (if you calculated it [-180,180]), you’ll need to add 360 degrees: so, if you specify -175 in Solcast, it should be 185 in this integration.
+1 to that…we need to remember Solcast or Open-Meteo are forecasting (so guessing with science ) on what might happen…
today was changeable where I am today and look at the Generation (green) vs Solcast Forecast (orange)…doesn’t make Solcast wrong it just means the forecast vs actual had a wider variance than it might…
I have panels facing east (90 degrees) and West (270 degrees) so I’ve created two integrations and sum these. solar production was quite close to Solcast
I’m not sure what to do with this information. At the end of the day, it’s a forecast and YMMV. The issue is that I don’t have any data/diagnostics to be able to see why it’s underestimating and having this data would necessitate knowing your location (or at least your rough location), which is something I’m very much not interested in.
Hi. I understand and agree. I don’t know how to fix it either. Just pointing it out. Having some estimate is better than nothing. Thanks for your work on this.
FWIW I’m currently on v 0.1.2 living in central England and I’m finding the prediction to be very good. I’ve moved away from Solcast because of the repository being taken down and I also found Forecast.solar to significantly under-read. So I’m very grateful for you putting up this repository, I use it to work out whether or not to charge the battery overnight.
I’m not very sure what you’re asking here without just reading the sensor names. The first sensor is the energy production for the current hour (i.e., if the time is 11:49 it will give the energy production from 11:00 → 11:59). The second sensor does that but for the next hour.
Wow what happened? I’ve actually contributed to the Solcast integration but only privately. I had a private fork I shared with him and he took some of my work for his integration. I think I got credited in the README but that might have been removed.
I am searching for a sensor that tells me the energy forecasted for the next 60mins. Would help my wife to decide if she is safe to run the dishwasher, …
Solcast dev got pissed of and deleted his complete user from GitHub together with his user here in the forum. So be prepared to get overrun by the people migrating to your integration
I guess you’d want to check the “This Hour” and “Next Hour” sensor then but you also have power sensors you could use that give you data at 15min intervals (Power Now, Power next 15min, Power next 30min, etc). The irradiance is interpolated for regions that aren’t Europe or the US.
