Why is this not working?
http://hassio:8123/api/services/scripts/camdetecon?api_password=1234
405: Method Not Allowed
Your question is quite unclear. What are you trying to do?
If you are trying to run script.camdetecon, you may try the curl command:
curl -X POST -H “Content-Type: application/json” -H “x-ha-access:1234” -d ‘{“entity_id”:“script.camdetecon”}’ http://hassio:8123/api/services/script/turn_on
I try to run script.camdetecon
This is what I had to do to run a script via curl. Mine is called MyTestScript
1- Create the script in the webUI under Configuration
→ Scripts
→ +Add Script
2- Once you create the script, note it’s entity ID. You can find this in the URL of the script when you are editing it, or by clicking on the button near the script in the list, or by querying the
/api/services
endpoint and looking for it under "domain": "script"
. Mine is script.mytestscript
3- Finally, run curl
with the following syntax:
curl -X POST -H "Authorization: Bearer XXX" -d '{"entity_id": "script.mytestscript"}' http://<ip>:8123/api/services/script/turn_on
I got the Auth token by creating one under the “Long-Lived Access Tokens” option under my user’s profile.
