Hi. I’m pretty new to HA. I have HA on a mini pc running HAOS by itself. I am trying to use a Sonoff Dongle Max for my Thread radio over ethernet. It has been working fine until the past couple of days. Now, OTBR will let me start it, but then it errors out after about 5 minutes. Let’s say for a second it isn’t ridiculous to try and use an ethernet connection here. Yes, I’ve seen the warning. What could’ve happened and can I fix it? Here’s some of the log. I don’t know what any of it means, so I hope what you need is in there. I bolded the parts that were in red.
[10:28:57] INFO: Starting socat TCP client for OTBR daemon...
Add-on: OpenThread Border Router
OpenThread Border Router app
Add-on version: 3.2.0
You are running the latest version of this add-on.
System: Home Assistant OS 18.3 (amd64 / generic-x86-64)
Home Assistant Core: 2026.9.3
Home Assistant Supervisor: 2026.09.2
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service socat-otbr-tcp successfully started
s6-rc: info: service otbr-agent: starting
[10:28:58] INFO: Setup OTBR firewall…
[10:28:58] INFO: Migrating OTBR settings if needed…
2026-09-26 10:28:58 homeassistant asyncio[256] DEBUG Using selector: EpollSelector
2026-09-26 10:28:58 homeassistant zigpy.serial[256] DEBUG Opening a serial connection to ‘/tmp/ttyOTBR’ (baudrate=460800, xonxoff=False, rtscts=True)
2026-09-26 10:28:58 homeassistant serialx.platforms.serial_posix[256] DEBUG Locking serial port ‘/tmp/ttyOTBR’
2026-09-26 10:28:58 homeassistant serialx.platforms.serial_posix[256] DEBUG Configuring serial port ‘/tmp/ttyOTBR’
2026-09-26 10:28:58 homeassistant serialx.platforms.serial_posix[256] DEBUG Configuring serial port: TcsetattrFlags(iflag=0, oflag=0, cflag=2147486896, lflag=0, ispeed=4100, ospeed=4100, cc_vmin=0, cc_vtime=0) + cc=[b’\x03’, b’\x1c’, b’\x7f’, b’\x15’, b’\x04’, 0, 0, b’\x00’, b’\x11’, b’\x13’, b’\x1a’, b’\x00’, b’\x12’, b’\x0f’, b’\x17’, b’\x16’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’]
2026-09-26 10:28:58 homeassistant serialx.platforms.serial_linux[256] DEBUG Setting low latency mode: True
2026-09-26 10:28:58 homeassistant serialx.platforms.serial_linux[256] DEBUG Device does not support setting low latency
2026-09-26 10:28:58 homeassistant serialx.platforms.serial_posix[256] DEBUG Setting modem pins: ModemPins[dtr rts]
2026-09-26 10:28:58 homeassistant serialx.platforms.serial_posix[256] DEBUG Setting TIOCMBIS: 0x00000006
2026-09-26 10:28:58 homeassistant serialx.platforms.serial_posix[256] DEBUG Device is not a serial port, cannot set modem pins
2026-09-26 10:28:58 homeassistant zigpy.serial[256] DEBUG Connection made: <serialx.platforms.serial_linux.LinuxSerialTransport object at 0x7f40414049d0>
2026-09-26 10:28:58 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=0, network_link_id=0, flag=2), command_id=<CommandID.RESET: 1>, data=b’\x02’)
2026-09-26 10:28:58 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending data b’~\x80\x01\x02\xea\xf0~’
2026-09-26 10:28:58 homeassistant serialx.descriptor_transport[256] DEBUG Immediately writing b’~\x80\x01\x02\xea\xf0~’
2026-09-26 10:28:58 homeassistant serialx.descriptor_transport[256] DEBUG Sent 7 of 7 bytes
2026-09-26 10:29:00 homeassistant universal_silabs_flasher.spinel[256] DEBUG Device did not respond to reset, continuing
2026-09-26 10:29:00 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b’\x08’)
2026-09-26 10:29:00 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending data b’~\x83\x02\x08\xbc\x9a~’
2026-09-26 10:29:00 homeassistant serialx.descriptor_transport[256] DEBUG Immediately writing b’~\x83\x02\x08\xbc\x9a~’
2026-09-26 10:29:00 homeassistant serialx.descriptor_transport[256] DEBUG Sent 7 of 7 bytes
2026-09-26 10:29:02 homeassistant universal_silabs_flasher.spinel[256] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b’\x08’), trying again in 0.10s (attempt 1 of 3)
2026-09-26 10:29:02 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b’\x08’)
2026-09-26 10:29:02 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending data b’~\x83\x02\x08\xbc\x9a~’
2026-09-26 10:29:02 homeassistant serialx.descriptor_transport[256] DEBUG Immediately writing b’~\x83\x02\x08\xbc\x9a~’
2026-09-26 10:29:02 homeassistant serialx.descriptor_transport[256] DEBUG Sent 7 of 7 bytes
2026-09-26 10:29:04 homeassistant universal_silabs_flasher.spinel[256] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b’\x08’), trying again in 0.10s (attempt 2 of 3)
2026-09-26 10:29:04 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b’\x08’)
2026-09-26 10:29:04 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending data b’~\x83\x02\x08\xbc\x9a~’
2026-09-26 10:29:04 homeassistant serialx.descriptor_transport[256] DEBUG Immediately writing b’~\x83\x02\x08\xbc\x9a~’
2026-09-26 10:29:04 homeassistant serialx.descriptor_transport[256] DEBUG Sent 7 of 7 bytes
2026-09-26 10:29:06 homeassistant universal_silabs_flasher.spinel[256] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b’\x08’), trying again in 0.10s (attempt 3 of 3)
2026-09-26 10:29:06 homeassistant serialx.descriptor_transport[256] DEBUG Closing at the request of the application
2026-09-26 10:29:06 homeassistant serialx.descriptor_transport[256] DEBUG Backgrounding a close request: None
2026-09-26 10:29:06 homeassistant zigpy.serial[256] DEBUG Waiting for serial port to close
2026-09-26 10:29:06 homeassistant serialx.descriptor_transport[256] DEBUG Closing connection: None
2026-09-26 10:29:06 homeassistant serialx.descriptor_transport[256] DEBUG Closing file descriptor 7
2026-09-26 10:29:06 homeassistant serialx.descriptor_transport[256] DEBUG Calling protocol `connection_lost` with exc=None
2026-09-26 10:29:06 homeassistant zigpy.serial[256] DEBUG Connection lost: None
File “/usr/local/lib/python3.13/dist-packages/universal_silabs_flasher/spinel.py”, line 260, in send_frame
return await asyncio.shield(future)
asyncio.exceptions.CancelledError
File “/usr/local/bin/migrate_otbr_settings.py”, line 228, in
asyncio.run(main())
File “/usr/lib/python3.13/asyncio/runners.py”, line 195, in run
return runner.run(main)
File “/usr/lib/python3.13/asyncio/runners.py”, line 118, in run
return self._loop.run_until_complete(task)
File “/usr/lib/python3.13/asyncio/base_events.py”, line 725, in run_until_complete
return future.result()
File “/usr/local/bin/migrate_otbr_settings.py”, line 156, in main
hwaddr = await get_adapter_hardware_addr(
…<3 lines>…
File “/usr/local/bin/migrate_otbr_settings.py”, line 103, in get_adapter_hardware_addr
rsp = await protocol.send_command(
…<2 lines>…
File “/usr/local/lib/python3.13/dist-packages/universal_silabs_flasher/spinel.py”, line 292, in send_command
return await self.send_frame(frame, **kwargs)
File “/usr/local/lib/python3.13/dist-packages/universal_silabs_flasher/spinel.py”, line 259, in send_frame
async with asyncio_timeout(timeout):
File “/usr/lib/python3.13/asyncio/timeouts.py”, line 116, in _aexit_
raise TimeoutError from exc_val
TimeoutError
[10:29:06] WARNING: otbr-agent exited with code 1 (by signal 0).
Chain OTBR_FORWARD_INGRESS (0 references)
target prot opt source destination
DROP all – anywhere anywhere PKTTYPE = unicast
DROP all – anywhere anywhere match-set otbr-ingress-deny-src src
ACCEPT all – anywhere anywhere match-set otbr-ingress-allow-dst dst
otbr-ingress-deny-src-swap
otbr-ingress-allow-dst-swap
Chain OTBR_FORWARD_EGRESS (0 references)
Chain OTBR_FORWARD_NAT64 (0 references)
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 mark match 0x1001
ACCEPT all – 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
[10:29:07] INFO: OTBR firewall/NAT64 rules teardown completed.
s6-svlisten: fatal: some services reported permanent failure or their supervisor died
s6-rc: warning: unable to start service otbr-agent: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service banner: stopping
s6-rc: info: service socat-otbr-tcp: stopping
s6-rc: info: service banner successfully stopped
2026/09/26 10:29:07 socat[89] W exiting on signal 15
s6-rc: info: service socat-otbr-tcp successfully stopped
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: warning: service s6rc-oneshot-runner is marked as essential, not stopping it
/package/admin/s6-overlay/libexec/preinit: info: container permissions: uid=0 (root), euid=0, gid=0 (root), egid=0
/package/admin/s6-overlay/libexec/preinit: info: /run permissions: uid=0 (root), gid=0 (root), perms=oxorgxgruxuwur
[10:31:59] INFO: Stable mode enabled.
[10:31:59] INFO: Web UI and REST API port are exposed, starting otbr-web.
[10:31:59] INFO: Enabled socat-otbr-tcp.
/run/s6/basedir/scripts/rc.init: info: hook /etc/s6-overlay/scripts/enable-check.sh exited 0
s6-rc: info: service socat-otbr-tcp: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service banner: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
[10:31:59] INFO: Starting socat TCP client for OTBR daemon…
[10:32:00] INFO: Setup OTBR firewall…
[10:32:00] INFO: Migrating OTBR settings if needed…
2026-09-26 10:32:00 homeassistant asyncio[256] DEBUG Using selector: EpollSelector
2026-09-26 10:32:00 homeassistant zigpy.serial[256] DEBUG Opening a serial connection to ‘/tmp/ttyOTBR’ (baudrate=460800, xonxoff=False, rtscts=True)
2026-09-26 10:32:00 homeassistant serialx.platforms.serial_posix[256] DEBUG Locking serial port ‘/tmp/ttyOTBR’
2026-09-26 10:32:00 homeassistant serialx.platforms.serial_posix[256] DEBUG Configuring serial port ‘/tmp/ttyOTBR’
2026-09-26 10:32:00 homeassistant serialx.platforms.serial_posix[256] DEBUG Configuring serial port: TcsetattrFlags(iflag=0, oflag=0, cflag=2147486896, lflag=0, ispeed=4100, ospeed=4100, cc_vmin=0, cc_vtime=0) + cc=[b’\x03’, b’\x1c’, b’\x7f’, b’\x15’, b’\x04’, 0, 0, b’\x00’, b’\x11’, b’\x13’, b’\x1a’, b’\x00’, b’\x12’, b’\x0f’, b’\x17’, b’\x16’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’, b’\x00’]
2026-09-26 10:32:00 homeassistant serialx.platforms.serial_linux[256] DEBUG Setting low latency mode: True
2026-09-26 10:32:00 homeassistant serialx.platforms.serial_linux[256] DEBUG Device does not support setting low latency
2026-09-26 10:32:00 homeassistant serialx.platforms.serial_posix[256] DEBUG Setting modem pins: ModemPins[dtr rts]
2026-09-26 10:32:00 homeassistant serialx.platforms.serial_posix[256] DEBUG Setting TIOCMBIS: 0x00000006
2026-09-26 10:32:00 homeassistant serialx.platforms.serial_posix[256] DEBUG Device is not a serial port, cannot set modem pins
2026-09-26 10:32:00 homeassistant zigpy.serial[256] DEBUG Connection made: <serialx.platforms.serial_linux.LinuxSerialTransport object at 0x7fcadec28850>
2026-09-26 10:32:00 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=0, network_link_id=0, flag=2), command_id=<CommandID.RESET: 1>, data=b’\x02’)
2026-09-26 10:32:00 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending data b’~\x80\x01\x02\xea\xf0~’
2026-09-26 10:32:00 homeassistant serialx.descriptor_transport[256] DEBUG Immediately writing b’~\x80\x01\x02\xea\xf0~’
2026-09-26 10:32:00 homeassistant serialx.descriptor_transport[256] DEBUG Sent 7 of 7 bytes
2026-09-26 10:32:02 homeassistant universal_silabs_flasher.spinel[256] DEBUG Device did not respond to reset, continuing
2026-09-26 10:32:02 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b’\x08’)
2026-09-26 10:32:02 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending data b’~\x83\x02\x08\xbc\x9a~’
2026-09-26 10:32:02 homeassistant serialx.descriptor_transport[256] DEBUG Immediately writing b’~\x83\x02\x08\xbc\x9a~’
2026-09-26 10:32:02 homeassistant serialx.descriptor_transport[256] DEBUG Sent 7 of 7 bytes
2026-09-26 10:32:04 homeassistant universal_silabs_flasher.spinel[256] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b’\x08’), trying again in 0.10s (attempt 1 of 3)
2026-09-26 10:32:04 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b’\x08’)
2026-09-26 10:32:04 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending data b’~\x83\x02\x08\xbc\x9a~’
2026-09-26 10:32:04 homeassistant serialx.descriptor_transport[256] DEBUG Immediately writing b’~\x83\x02\x08\xbc\x9a~’
2026-09-26 10:32:04 homeassistant serialx.descriptor_transport[256] DEBUG Sent 7 of 7 bytes
2026-09-26 10:32:06 homeassistant universal_silabs_flasher.spinel[256] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b’\x08’), trying again in 0.10s (attempt 2 of 3)
2026-09-26 10:32:06 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b’\x08’)
2026-09-26 10:32:06 homeassistant universal_silabs_flasher.spinel[256] DEBUG Sending data b’~\x83\x02\x08\xbc\x9a~’
2026-09-26 10:32:06 homeassistant serialx.descriptor_transport[256] DEBUG Immediately writing b’~\x83\x02\x08\xbc\x9a~’
2026-09-26 10:32:06 homeassistant serialx.descriptor_transport[256] DEBUG Sent 7 of 7 bytes
2026-09-26 10:32:08 homeassistant universal_silabs_flasher.spinel[256] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b’\x08’), trying again in 0.10s (attempt 3 of 3)
2026-09-26 10:32:08 homeassistant serialx.descriptor_transport[256] DEBUG Closing at the request of the application
2026-09-26 10:32:08 homeassistant serialx.descriptor_transport[256] DEBUG Backgrounding a close request: None
2026-09-26 10:32:08 homeassistant zigpy.serial[256] DEBUG Waiting for serial port to close
2026-09-26 10:32:08 homeassistant serialx.descriptor_transport[256] DEBUG Closing connection: None
2026-09-26 10:32:08 homeassistant serialx.descriptor_transport[256] DEBUG Closing file descriptor 7
2026-09-26 10:32:08 homeassistant serialx.descriptor_transport[256] DEBUG Calling protocol `connection_lost` with exc=None
2026-09-26 10:32:08 homeassistant zigpy.serial[256] DEBUG Connection lost: None
asyncio.run(main())
…<3 lines>…
…<2 lines>…
TimeoutError
[10:32:08] WARNING: otbr-agent exited with code 1 (by signal 0).
[10:32:08] INFO: OTBR firewall/NAT64 rules teardown completed.
2026/09/26 10:32:08 socat[89] W exiting on signal 15
