I currently run Home assistant via Kubernetes, i am not sure how do i need to add openwakeword support honestly, i tried running a container on the same pod exposing 10400:tcp but its not detected, i then tried opening that as a cluster ip resource or even a node port but still no luck, can this be configured manually somewhere to tell HA where the openwakeword container is listening? I cannot install the addon so i am stuck (the OWW integration is not detected in the voice assistant settings)
I will answer myself, you can safely add an OWW container to your pod and use port 10400, you then need to go to integrations, add a whyoming integration and specifically point it to 127.0.0.1:10400
