🪟 Open Window Recommendation | Absolute Humidity Based Blueprint
Dynamic Ventilation Recommendation (based on Absolute Humidity)
This blueprint calculates the absolute humidity (AH) indoors and outdoors from temperature and relative humidity sensors. If the AH indoors exceeds the AH outdoors by a configurable threshold (default: 3 g/m³), a ventilation recommendation is triggered.
If the window is still open when the humidity is back to normal, a reminder to close it is sent.
Features
  • Calculates AH from temp & humidity (no external sensor needed)
  • Periodic check every 5 minutes
  • Adjustable threshold
  • Room name for personalized messages
  • Works with any notify service (e.g. mobile app, Alexa)
  • Supports presence-based filtering (only notify if someone is home)
Inputs
  • Indoor & outdoor temperature and humidity sensors
  • Binary sensor for window status
  • Notify service
  • Room name
  • Threshold for AH difference
Example use case
You can set up one automation per room (e.g. bathroom, living room, bedroom) using this blueprint with different sensor inputs.
blueprint:
  name: Dynamic Ventilation Recommendation (based on Absolute Humidity)
  description: >
    Calculates absolute humidity indoors and outdoors based on temperature
    and relative humidity, and recommends ventilation when the difference
    exceeds a defined threshold.
  domain: automation
  input:
    temp_inside:
      name: Indoor temperature sensor
      selector:
        entity:
          domain: sensor
    rh_inside:
      name: Indoor humidity sensor
      selector:
        entity:
          domain: sensor
    temp_outside:
      name: Outdoor temperature sensor
      selector:
        entity:
          domain: sensor
    rh_outside:
      name: Outdoor humidity sensor
      selector:
        entity:
          domain: sensor
    window_sensor:
      name: Window open sensor
      selector:
        entity:
          domain: binary_sensor
    notify_push:
      name: Push notification service (e.g. notify.notify)
      selector:
        text:
    notify_tts:
      name: (Optional) TTS service for Alexa (e.g. notify.alexa_media_kitchen)
      default: ""
      selector:
        text:
    room_name:
      name: Room name (used in messages)
      selector:
        text:
    threshold:
      name: Threshold for AH difference (g/m³)
      default: 3
      selector:
        number:
          min: 0.5
          max: 10
          step: 0.1
          unit_of_measurement: "g/m³"
    message_ventilate:
      name: Message when ventilation is recommended
      default: "{{ room_name }} should be ventilated. (AH indoor {{ af_in | round(1) }} > outdoor {{ af_out | round(1) }} g/m³)"
      selector:
        text:
    message_close:
      name: Message when window can be closed
      default: "Humidity in {{ room_name }} is back to normal (AH indoor {{ af_in | round(1) }} ≤ outdoor + threshold {{ af_out | round(1) + threshold | round(1) }} g/m³). You can close the window."
      selector:
        text:
  - platform: time_pattern
    minutes: "/5"
condition:
  - condition: numeric_state
    entity_id: zone.home
    above: 0.5
variables:
  t_in: "{{ states(temp_inside) | float }}"
  rh_in: "{{ states(rh_inside) | float }}"
  t_out: "{{ states(temp_outside) | float }}"
  rh_out: "{{ states(rh_outside) | float }}"
  af_in: >
    {{ (6.112 * exp((17.67 * t_in)/(t_in + 243.5)) * rh_in * 2.1674) / (273.15 + t_in) }}
  af_out: >
    {{ (6.112 * exp((17.67 * t_out)/(t_out + 243.5)) * rh_out * 2.1674) / (273.15 + t_out) }}
  delta_af: "{{ af_in - af_out }}"
  tag_ventilate: "{{ 'ventilate_' ~ room_name | lower | replace(' ', '_') }}"
  tag_close: "{{ 'ventilate_' ~ room_name | lower | replace(' ', '_') }}"
  - choose:
      - conditions:
          - condition: template
            value_template: "{{ delta_af | float > threshold | float }}"
        sequence:
          - service: "{{ notify_push }}"
              message: "{{ message_ventilate }}"
                tag: "{{ tag_ventilate }}"
          - choose:
              - conditions:
                    value_template: "{{ notify_tts != '' }}"
                sequence:
                  - service: "{{ notify_tts }}"
                        type: announce
      - conditions:
            value_template: "{{ delta_af | float <= threshold | float }}"
          - condition: state
            entity_id: !input window_sensor
            state: "on"
        sequence:
              message: "{{ message_close }}"
                tag: "{{ tag_close }}"
          - choose:
              - conditions:
                sequence:
                        type: announce
mode: single
Hello there.
I have problems with installation of this Blueprint. I have every thing needed (Temperature for every room, relatvie Humidity for every room indoors, and i use a virtual temperature/ relative humidity sensor for outside based on the Forcast Meteorologie add on) I also use Window sensors. My problem now is that if i configurate it how it is telling me to do, the automation is not working. Has anyone, any advise where i could have done something wrong or what are the useuall missunderstanding with this blueprint.
My Homassistant log protokoll Errors this:
Logger: homeassistant.components.automation.dynamic_ventilation_recommendation_based_on_absolute_humidity_4
Quelle: components/automation/init.py:749
Integration: Automation (Dokumentation, Problems)
Error rendering variables: UndefinedError: ‘temp_inside’ is undefined
That would be very helpfull
Hello @marctws3101
Try my blueprint:
I also had issues with blueprint from @lukinho9821 so I fixed it and extended functionality of this blueprint a lot.
Bug: exp() is not a valid Jinja function in Home Assistant
The blueprint’s absolute-humidity calculation uses exp((17.67 * t_in)/(t_in + 243.5)) in both af_in and af_out. Home Assistant’s Jinja sandbox doesn’t expose an exp() global function — every automation using this blueprint fails silently on this template (raises UndefinedError, no ventilation recommendation ever fires).
Confirmed with a minimal test: {{ exp(1) }} errors out on a current HA install (2026.9).
Fix: replace exp(x) with 2.718281828459045 ** (x) — plain ** worked reliably in testing:
af_in: ‘{{ (6.112 * (2.718281828459045 ** ((17.67 * t_in)/(t_in + 243.5))) * rh_in * 2.1674) / (273.15 + t_in) }}’
af_out: ‘{{ (6.112 * (2.718281828459045 ** ((17.67 * t_out)/(t_out + 243.5))) * rh_out * 2.1674) / (273.15 + t_out) }}’
Verified this produces plausible values (e.g. ~10.5 g/m³ for a typical living room), matching independently-tracked absolute-humidity sensors.
Separately, a design note: window_sensor is a required input, but it’s only used to gate the “you can close the window” message — rooms without a trackable window (e.g. a windowless bathroom) have no valid value to supply. Might be worth making it optional, skipping that condition when unset.
