Had to muck with symlinks to get OpenZwave to start but worked through that.
Now I can’t get OpenZwave to recognize my AEON LABS Zstick 2.
my dmesg:
[195405.213315] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
[195405.213372] cp210x 1-1.2:1.0: device disconnected
[281595.334594] usb 1-1.2: new full-speed USB device number 6 using dwc_otg
[281595.471098] usb 1-1.2: New USB device found, idVendor=10c4, idProduct=ea60
[281595.471111] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[281595.471119] usb 1-1.2: Product: CP2102 USB to UART Bridge Controller
[281595.471127] usb 1-1.2: Manufacturer: Silicon Labs
[281595.471135] usb 1-1.2: SerialNumber: 0001
[281595.474182] cp210x 1-1.2:1.0: cp210x converter detected
[281595.483125] usb 1-1.2: cp210x converter now attached to ttyUSB0
I stop HomeAssistant and start OpenZwave:
2017-09-16 18:29:03.331 Always, OpenZwave Version 1.4.2723 Starting Up
webserver starting port 8888
post: key=dev data=\dev\ttyUSB0 size=12
post: key=fn data=open size=4
post: key=usb data=false size=5
2017-09-16 18:29:26.958 Info, Setting Up Provided Network Key for Secure Communications
2017-09-16 18:29:26.958 Warning, Failed - Network Key Not Set
2017-09-16 18:29:26.959 Info, mgr, Added driver for controller \dev\ttyUSB0
2017-09-16 18:29:26.960 Info, Opening controller \dev\ttyUSB0
2017-09-16 18:29:26.960 Info, Trying to open serial port \dev\ttyUSB0 (attempt 1)
2017-09-16 18:29:26.960 Error, ERROR: Cannot open serial port \dev\ttyUSB0. Error code 2
2017-09-16 18:29:26.960 Error, ERROR: Failed to open serial port \dev\ttyUSB0
2017-09-16 18:29:26.960 Warning, WARNING: Failed to init the controller (attempt 0)
2017-09-16 18:29:31.961 Info, Opening controller \dev\ttyUSB0
2017-09-16 18:29:31.961 Info, Trying to open serial port \dev\ttyUSB0 (attempt 1
Don’t use OpenZWave’s control panel, you don’t need it and it may just complicate things for you.
The stick will know about the paired devices. Are you saying that none show up in your HA dev-states? Do you have a zwcfg_*.xml file in /home/homeassistant/.homeassistant/?
