Sorry, I should have explained myself better,
What I meant by “I can’t get anything to work” was in regards to ZWAVE. HASS is running fine in all other respects.
I followed the Zwave install instructions from the All In One installer page but I didn’t have much luck as I assume some of the directories differ from the Hassbian image, which is what I’m running, I also followed the BRUH video… I noticed this in the comments:
Will these steps also work if I have HASSbian image? It seems I cannot find the open-zwave-control-panel to configure.
And the response from Ben was:
Kind of. The commands are slightly different. Plus, with Hassbian you’ll need to install OpenZWave first as outlined on the Hassbian info page. It’s a bit of a pain, but the instructions are good. I’m still running the AiO method, though. If you’d rather, you can hop over that install method to avoid the hassle. Cheers!
Following the link in the Hassbian page takes me to the regular Zwave install page. i can’t find any other instructions specific to the Hassbian image.
I came across this while doing some forum searching but I didn’t have much luck with is solving my issue:
i’m able to install openzwave properly, but getting it to talk to HA with the right permissions is where i’m having problems. I’ve set up openzwave twice before using both the all-in-one installer and from scratch. here’s what i have so far:
sudo apt-get install cython3 libudev-dev python3-sphinx python3-setuptools git
enter homeassistant user and update virtualenv to the right version of cython. NOTE: in the hassbian image pip3 points to the system pip3 and not to the virtualenv pip, so if you use pip3 the build steps won’t work
sudo su -s /bin/bash homeassistant
source /srv/homeassistant/bin/activate
pip install --upgrade cython
exit
create the directory
cd /srv
sudo mkdir python-openzwave
sudo chown pi:pi python-openzwave
grab the project from git
git clone GitHub - OpenZWave/python-openzwave: Python wrapper for openzwave
from here you should be able to follow the steps in the getting started z-wave page to get openzwave built.
