Many times, when I have to restart my HA system (hassio on an Intel NUC, Debian 9 stretch, Aeotec zwave stick) ZWave doesn’t start.
I have about 50 devices. Now they’re all gone.
I need help! Please?
My ozw-log file after a start and manual stop looks like this:
2018-11-27 18:19:32.311 Always, OpenZwave Version 1.4.3254 Starting Up
2018-11-27 18:19:35.493 Info, Setting Up Provided Network Key for Secure Communications
2018-11-27 18:19:35.493 Warning, Failed - Network Key Not Set
2018-11-27 18:19:35.493 Info, mgr, Added driver for controller /dev/ttyACM0
2018-11-27 18:19:35.493 Info, Opening controller /dev/ttyACM0
2018-11-27 18:19:35.493 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2018-11-27 18:19:35.493 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2018-11-27 18:19:35.494 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2018-11-27 18:19:35.494 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2018-11-27 18:19:35.494 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2018-11-27 18:19:35.494 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2018-11-27 18:19:35.494 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2018-11-27 18:19:35.494 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2018-11-27 18:19:36.494 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-11-27 18:19:36.494 Detail, contrlr, Removing current message
2018-11-27 18:19:36.494 Detail, contrlr, Notification: Notification - TimeOut
2018-11-27 18:19:36.497 Detail,
2018-11-27 18:19:36.497 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2018-11-27 18:19:37.499 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-11-27 18:19:37.500 Detail, contrlr, Removing current message
2018-11-27 18:19:37.500 Detail, contrlr, Notification: Notification - TimeOut
2018-11-27 18:19:37.500 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2018-11-27 18:19:38.502 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-11-27 18:19:38.502 Detail, contrlr, Removing current message
2018-11-27 18:19:38.502 Detail, contrlr, Notification: Notification - TimeOut
2018-11-27 18:19:38.503 Detail,
2018-11-27 18:19:38.503 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2018-11-27 18:19:39.504 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-11-27 18:19:39.504 Detail, contrlr, Removing current message
2018-11-27 18:19:39.504 Detail, contrlr, Notification: Notification - TimeOut
2018-11-27 18:19:39.504 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2018-11-27 18:19:40.504 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-11-27 18:19:40.504 Detail, contrlr, Removing current message
2018-11-27 18:19:40.504 Detail, contrlr, Notification: Notification - TimeOut
2018-11-27 18:24:58.772 Error, mgr, Manager::GetDriver failed - Home ID 0x00000000 is unknown
2018-11-27 18:24:58.772 Warning, Exception: Manager.cpp:373 - 100 - Invalid HomeId passed to GetDriver
2018-11-27 18:24:58.772 Info, mgr, Manager::WriteConfig failed - _homeId 0 not found
2018-11-27 18:24:59.775 Detail, Notification: DriverRemoved
2018-11-27 18:24:59.775 Always, ***************************************************************************
2018-11-27 18:24:59.776 Always, ********************* Cumulative Network Statistics *********************
2018-11-27 18:24:59.776 Always, *** General
2018-11-27 18:24:59.776 Always, Driver run time: . . . 0 days, 0 hours, 5 minutes
2018-11-27 18:24:59.776 Always, Frames processed: . . . . . . . . . . . . . . . . . . . . 0
2018-11-27 18:24:59.776 Always, Total messages successfully received: . . . . . . . . . . 0
2018-11-27 18:24:59.776 Always, Total Messages successfully sent: . . . . . . . . . . . . 5
2018-11-27 18:24:59.776 Always, ACKs received from controller: . . . . . . . . . . . . . 0
2018-11-27 18:24:59.776 Always, *** Errors
2018-11-27 18:24:59.776 Always, Unsolicited messages received while waiting for ACK: . . 0
2018-11-27 18:24:59.776 Always, Reads aborted due to timeouts: . . . . . . . . . . . . . 0
2018-11-27 18:24:59.776 Always, Bad checksum errors: . . . . . . . . . . . . . . . . . . 0
2018-11-27 18:24:59.776 Always, CANs received from controller: . . . . . . . . . . . . . 0
2018-11-27 18:24:59.776 Always, NAKs received from controller: . . . . . . . . . . . . . 0
2018-11-27 18:24:59.776 Always, Out of frame data flow errors: . . . . . . . . . . . . . 0
2018-11-27 18:24:59.776 Always, Messages retransmitted: . . . . . . . . . . . . . . . . . 0
2018-11-27 18:24:59.776 Always, Messages dropped and not delivered: . . . . . . . . . . . 5
2018-11-27 18:24:59.776 Always, ***************************************************************************
2018-11-27 18:24:59.776 Warning, WARNING: Tried to write driver config with no home ID set
2018-11-27 18:25:01.779 Info, mgr, Driver for controller /dev/ttyACM0 removed
