OpenAI ask me questions and execute my answer
Since after I integrated Extended OpenAI Conversation I was looking for a way to automate OpenAI asking me questions and executing my answer, as I haven’t found another solution in the forums, I am sharing mine.
I managed to find a way of doing it by using the awesome integration from AlexxIT StreamAssist that allow us to use any camera to activate assist.
With this integration you can select at what stage of the pipeline to start.
I created a script that start the pipeline from the intent and I pass the intent directly as ’ Ask me: “Do you want to turn on the mirror light ?”
Then I activate the pipeline once again starting from STT (Speach to text) so skipping the wakeword.
Both scripts are using the same conversation_id so that OpenAI will remember what it asked.
Example of a working script:
alias: OpenAI ask questions
sequence:
  - service: stream_assist.run
      camera_entity_id: camera.reolink_sala_1_sub
      player_entity_id: media_player.tablet
      stt_start_media: media-source://media_source/local/beep.mp3
      assist:
        start_stage: intent #Start the voice pipeline directly from the intent
        end_stage: tts
        intent_input: >-
          Ask me "Do you want to turn on the mirror's light?" #The intent provided is the question that OpenAI have to ask me
        conversation_id: 01HV8SNMZXEHKJYYR38GD2Y27G #Conversation_ID is fundamental to allow OpenAI to remember the question when I'll answer
  - delay: #Delay is required to give OpenAI the time to complete the question before starting the assistant again
      hours: 0
      minutes: 0
      seconds: 5
      milliseconds: 0
    enabled: true
      assist:
        start_stage: stt #Now starting the pipeline from Speach To Text so I can answer
        end_stage: tts
    enabled: true
mode: single
Probably there is a way to do sort of the same without Stream Assist.
This is excellent. Searched all net only this one bring a light for continous conversation. I write a Continuous Conversation Script based on your example:
alias: AI ask questions
sequence:
  - alias: Ask me a question
      player_entity_id: media_player.kodi
      assist:
        start_stage: intent
        end_stage: tts
        intent_input: ask me "Yes?"
    response_variable: cv_response
  - alias: Loop listen & execution Until Continue_Conversation is on
    repeat:
      sequence:
        - alias: Sequence to flag for continue conversation or not
          sequence:
            - variables:
                resp_type: >-
                  cv_response['intent-end'].data.intent_output.response.response_type
                resp_last_input_speech: "{{ cv_response['intent-start'].data.intent_input }}"
                resp_last_output_speech: >-
                  cv_response['intent-end'].data.intent_output.response.speech.plain.speech
                resp_last_char: "{{ resp_last_output_speech[-4:] }}"
              alias: >-
                Get resp_type, initialize resp_last_speeches (input & output),
                resp_last_char and continuous flag
            - service: system_log.write
              metadata: {}
                level: error
                message: >-
                  {{ resp_last_input_speech }} || {{ resp_last_output_speech }}
                  || {{ resp_last_char }} || {{ resp_type}} || {{ ("?" in
                  resp_last_char) or ("?" in resp_last_char) }}
            - if:
                - condition: template
                  value_template: "{{ (\"?\" in resp_last_char) or (\"?\" in resp_last_char) }}"
                  alias: Test is last speech ended with a "?" marked
              then:
                  metadata: {}
                  data: {}
                    entity_id: input_boolean.continue_conversation
              else:
                - service: input_boolean.turn_off
                  metadata: {}
                  data: {}
              enabled: true
              alias: Decison to set continue flag "ON" or "OFF" ?
        - alias: Listen to user if continue flag "ON"
          if:
            - condition: state
              state: "on"
          then:
            - wait_for_trigger:
                - platform: state
                  entity_id:
                    - media_player.kodi
                  to: idle
                  enabled: true
              timeout:
                hours: 0
                minutes: 1
                seconds: 0
                milliseconds: 0
              enabled: true
              continue_on_timeout: true
            - alias: Listen and execute user speech
                stream_source: rtsp://192.168.2.34/unicast
                assist:
                  start_stage: stt
                  end_stage: tts
                pipeline_id: 01gzv2xe278epc0svn0cgm3p3p
              enabled: true
      until:
        - condition: state
          state: "off"
          enabled: true
mode: single
description: ""
fields: {}
