OpenAQ has a pretty decent coverage map and data set. Some of the air quality services currently supported are a little slow to update, so more sources are always welcome.
This is an old post, but I just set this up for my instance using the Rest integration.
Pre-Requisites: You may need to register wirh openaq to get an API Key. I did.
On the OpenAQ website, you will need to find the location id for the location you want to measure. Then, you could configure things like this:
rest:
resource: https://api.openaq.org/v3/locations/$YOURLOCATION/sensors
headers: {"X-API-Key": "$YOURAPIKEY"}
scan_interval: 300
- name: "openaq.o3"
device_class: "ozone"
unit_of_measurement: "µg/m³"
force_update: true
value_template: "{{ value_json.results[0].latest.value }}"
- name: "openaq.pm25"
device_class: "pm25"
force_update: true
value_template: "{{ value_json.results[1].latest.value }}"
- name: "openaq.no"
device_class: "nitrogen_monoxide"
force_update: true
value_template: "{{ value_json.results[2].latest.value }}"
- name: "openaq.no2"
device_class: "nitrous_oxide"
value_template: "{{ value_json.results[3].latest.value }}"
- name: "openaq.pm10"
device_class: "pm10"
force_update: true
value_template: "{{ value_json.results[4].latest.value }}"
I used JSON Pathfinder to inspect the results of the API call for my location. I expect different locations to have different json results.
