Hello, i get the following errors!
[homeassistant.components.image_processing.opencv] No opencv library found! Install or compile for your system following instructions here: http://opencv.org/releases.html
What can i do? I use Home Assistant 0.47.0 and Supervisor 0.37
same issue here on a Ubuntu 16 VM
Is the component supposed to install opencv itself?
Where is hass looking for the library?
(hass) hass@hass:~$ sudo pip3 show opencv-python Name: opencv-python Version: 3.3.0.10 Location: /usr/local/lib/python3.5/dist-packages
should it be in the install folder here?
/srv/hass/lib/python3.5/site-packages
