I have an OpenEVSE with the older ESP8266 v2 WiFi module. Its HTTP API is a bit flakey but MQTT works fine. So I set up a custom device using MQTT discovery. Using an MQTT client like mosquitto_pub or MQTT Explorer send the following payloads to their respective topic.
Change the hexnumber to something unique. I used its MAC address.
Also if you have another topic prefix than ‘openevse’ then change that too.
The min and max of the pilot current might need to be changed for how much your circuit breaker can handle.
homeassistant/sensor/openevse-84f3eb948235/charge_current/config
"name": "OpenEVSE charge current",
"device": {
"identifiers": [
"openevse_84f3eb948235_mqtt"
"name": "OpenEVSE"
"device_class": "current",
"unit_of_measurement": "A",
"unique_id": "openevse-84f3eb948235-charge-current",
"state_topic": "openevse/amp",
"value_template": "{{ float(value) / 1000.0 }}",
"icon": "mdi:ev-station"
homeassistant/sensor/openevse-84f3eb948235/state/config
"name": "OpenEVSE state",
"device": {
"identifiers": [
"name": "OpenEVSE"
"unique_id": "openevse-84f3eb948235-state",
"state_topic": "openevse/state",
"value_template": "{% set evsestates = {'0':'unknown', '1':'not connected', '2':'connected', '3':'charging', '4':'vent required', '5':'diode check failed', '6':'gfci fault', '7':'no ground', '8':'stuck relay', '9':'gfci self-test failure', '10':'over temperature', '254':'sleeping', '255':'disabled'} %}{{ evsestates[value] if value in evsestates else 'unknown' }}",
homeassistant/sensor/openevse-84f3eb948235/total_energy/config
"name": "OpenEVSE total energy",
"device": {
"identifiers": [
"name": "OpenEVSE"
"device_class": "energy",
"state_class": "total_increasing",
"unit_of_measurement": "kWh",
"unique_id": "openevse-84f3eb948235-total-energy",
"state_topic": "openevse/wh",
homeassistant/number/openevse-84f3eb948235/pilot_current/config
"name": "OpenEVSE pilot current",
"device": {
"identifiers": [
"name": "OpenEVSE"
"unique_id": "openevse-84f3eb948235-pilot-current",
"state_topic": "openevse/pilot",
"command_topic": "openevse/rapi/in/$SC",
"icon": "mdi:ev-station",
"min": 6,
"max": 16
homeassistant/button/openevse-84f3eb948235/disable/config
"name": "OpenEVSE disable",
"device": {
"identifiers": [
"name": "OpenEVSE"
"unique_id": "openevse-84f3eb948235-disable",
"command_topic": "openevse/rapi/in/$FD",
homeassistant/button/openevse-84f3eb948235/enable/config
"name": "OpenEVSE enable",
"device": {
"identifiers": [
"name": "OpenEVSE"
"unique_id": "openevse-84f3eb948235-enable",
"command_topic": "openevse/rapi/in/$FE",
