Hi, I did a DIY opengarage Garage opener (a nodemCU plus HC-SR04 ultrasonic sensor)
and flashed this firmware:
It works great, but wish to bring everything ESP related flashed with ESPhome, has anyone a working yaml code for it?
Thank you, very useful.
In case anyone is interested and finds this older post via search I thought I would show my take on converting the same parts used for the OpenGarage DIY to be used for ESPHome. It doesn’t provide a web page frontend but it does pretty much the same job.
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: "yourwifissid"
password: "yourwifipassword"
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
- platform: ultrasonic
trigger_pin: D6
echo_pin: D5
update_interval: 5s
unit_of_measurement: cm
accuracy_decimals: 0
name: "Door Position Sensor"
# apply a filter to change the distance to cm from metre #
filters:
- multiply: 100
- platform: wifi_signal
name: "Garage Opener Wifi"
update_interval: 60s
switch:
- platform: gpio
pin: D8
name: "Garage Door Switch"
# restart gives a switch in HA that can be used to reboot the NodeMCU #
- platform: restart
name: garage opener restart
# is the output used to create a buzzer #
output:
- platform: esp8266_pwm
pin: D7
cover:
# set the value so that it is higher than value when door is in open state. In my case it reads 5cm so set it at 10cm #
lambda: !lambda |-
if (id(door_sensor).state < 10) {
return COVER_OPEN;
} else {
return COVER_CLOSED;
open_action:
# Cancel any previous action
- switch.turn_off: open_switch
# sound buzzer before door opens
- output.esp8266_pwm.set_frequency:
frequency: 800Hz
- output.set_level:
level: 50%
- delay: 5s
- output.turn_off: buzzer
# Turn the OPEN/CLOSE switch/relay on briefly
- switch.turn_on: open_switch
- delay: 0.2s
close_action:
# sound buzzer before door closes
frequency: 800Hz
- output.set_level:
level: 50%
- delay: 5s
- delay: 0.2s
stop_action:
- delay: 0.1s
# don't really need these here since they are set to default values anyway. was using before I got the ultrasonic sensor working #
optimistic: false
assumed_state: false
Hey I was curious if you’ve made any modifications to this since its been a while, I’m about to follow suit myself.
Still the same code being used for my setup.
Hi There. If i have to add MQTT to this and publish all this by MQTT, how will i do?
substitute the mqtt setup from esphome.io for the api line.
I went with something similar but with a few differences:
I’m new to ESPhome so there may be better ways to do what I did below.
substitutions:
devicename: garagedoor
description: OpenGarage.io Device
friendly_name: Garage Overhead Door
auto_close_delay: "600s" # 10 minutes
buzzer_delay: "0.5s"
open_distance: "15" # less than or equal in cm
open_close_time: "20s" # allow 20s for motion to complete
reporting_delta: "25" # minimum 25cm change
# Device informations
esphome:
comment: ${description}
platform: ESP8266
board: nodemcuv2
esp8266_restore_from_flash: false
# Configure WiFi
wifi:
ssid: "(your SSID)"
password: "(your password)"
ap: # Enable fallback hotspot in case wifi connection fails
ssid: "ESPHome"
# Enable captive portal in case wifi connection fails
captive_portal:
# Provides basic web interface and firmware upload capability
web_server:
port: 80
# Enable logging
logger:
level: INFO
baud_rate: 0 # Disable logging to serial
api:
# Enable OTA updates
ota:
# Enable status LED
status_led:
pin:
number: D0
inverted: yes
# Define switches/relays
switch:
# The door opener contact (internal)
- platform: gpio
pin: D8
restore_mode: ALWAYS_OFF
internal: true
on_turn_on:
- delay: 500ms
- switch.turn_off: garage_button
output:
frequency: 750Hz
pin: D7
# Define sensors
binary_sensor:
- platform: status
name: "${friendly_name} WiFi Signal"
name: "${friendly_name} Distance"
trigger_pin: D6
echo_pin: D5
update_interval: 2s
pulse_time: 10us
timeout: 4.0m
filters:
- filter_out: nan # filter timeouts
- multiply: 100 # from meter to cm
- sliding_window_moving_average:
window_size: 10
send_every: 5
send_first_at: 5
- delta: ${reporting_delta}
cover:
device_class: garage
# set the distance so it is equal or less than $open_distance when open
lambda: !lambda |-
if (id(${devicename}_distance).state <= ${open_distance}) {
return COVER_OPEN;
} else {
open_action:
- if:
condition:
lambda: "return id(${devicename}_control).position == cover::COVER_CLOSED;"
then:
- output.set_level:
level: 50%
- delay: ${buzzer_delay}
- switch.turn_on: garage_button
- delay: ${open_close_time}
- script.execute: auto_close
close_action:
- if:
condition:
lambda: "return id(${devicename}_control).position == cover::COVER_OPEN;"
then:
- output.set_level:
level: 50%
- output.set_level:
level: 50%
- output.set_level:
level: 50%
# Disable any auto close pending action
- script.stop: auto_close
script:
- id: auto_close
then:
- logger.log: "Automtically closing in ${auto_close_delay}"
- delay: ${auto_close_delay}
- logger.log: "Initiating automatic garage closing"
- cover.close: ${devicename}_control
Does this work with the latest version of opengarage hardware? when i flash this, it just bricks and doesn’t boot up.
./Sooraj
Define please?
I’m not sure what version mine is, I bought it back in January of 2020 and it looks the same as the version in the photo they have in the store with the acrylic case.
What steps did you take to flash it? Was it through the OpenGarage web interface?
I compiled the yaml in esphome, downloaded it and upgraded via the web interface. it said upgrade successful, but nothing turned up in my network. The hardware that i have, the chip covering says ESP12n. seems to be a derivation of ESP8266EX. How did you loaded? via the serial interface? as the model that i have dont have the serial to usb chip and has to be reflashed using FTDI adapter.
looks like the latest version of hardware that they sell dont have the serial to usb chip. so if i have to reflash it, i have to do it via the FTDI adaptor, like how we flash old sonoff devices.
I loaded via the web interface. If the device did not show up on your wi-fi, did you ensure that it isn’t broadcasting its own AP?
Yup. tried everything.
Could you also tell me if the code above will detect if the car is in the garage or not? i didnt see any status for the same when i read through the code. Also how can i publish the whole status and control everything via mqtt rather than ha api, as the garage is in separate network.
Unfortunately, you’ll likely need to try a serial flash then.
The code above will not check for vehicle presence. You’d have to make some changes to do that, perhaps create a template sensor in ESPHome that evaluates the ultrasonic distance and sets the vehicle status to true if the distance is greater than the garage open distance but less than or equal to the distance threshhold to the top of your car. See: https://esphome.io/components/text_sensor/template.html
If you don’t want to use the native API, you can use the MQTT client component instead: https://esphome.io/components/mqtt.html
My OpenGarage also ended up in a bootloop. I have this version, please note the wifi shield being under the ultrasonic sensor:
The bootloop comes from the wrong pinout. The correct pinout for this version is listed here:
/** GPIO pins */
#define PIN_RELAY 15 //D8 on nodemcu
#define PIN_BUTTON 0
#define PIN_TRIG 12 //D6 on nodemcu
#define PIN_ECHO 14 //D5 on nodemcu
#define PIN_LED 2
#define PIN_RESET 16
#define PIN_BUZZER 13
#define PIN_SWITCH 4 //switch sensor: D2 on nodemcu
#define PIN_TH 5 //temeprature sensor: D1 on nodemcu
Just use the numbers instead of the Dx.
PS. To add a nice ring on boot:
esphome:
platform: ESP8266
board: nodemcuv2
on_boot:
priority: 800
then:
- output.set_level: {id: buzzer, level: 10%}
- delay: "0.1s"
- output.set_level: {id: buzzer, level: 20%}
- delay: "0.1s"
- output.set_level: {id: buzzer, level: 30%}
- delay: "0.1s"
- output.set_level: {id: buzzer, level: 40%}
- delay: "0.1s"
- output.set_level: {id: buzzer, level: 50%}
- delay: "0.1s"
- output.set_level: {id: buzzer, level: 60%}
- delay: "0.1s"
- output.set_level: {id: buzzer, level: 70%}
- delay: "0.1s"
- output.set_level: {id: buzzer, level: 80%}
- delay: "0.1s"
- output.set_level: {id: buzzer, level: 90%}
- delay: "0.1s"
