I have tried to use the Openhardwaremonitor integration, it does not work.
I have opened the correct ports and gone as far as disabling the firewall on the computer running open hardware monitor.
I have checked to see if it can be accessed externally and the web server is running. It can. I even went to the /data.json url and it displayed data. I have even done this from the host running home assistant. (On Docker image)
I have set the logs to debug for Openhardwaremonitor monitor. It does not even show up in logs whatsoever. I checked using the logs part of configuration.
Why is home assistant not using Openhardwaremonitor? Do I need to install it? It appears to be something already installed I think. What’s going on?
