Hi
I was hoping that someone has experience with installing openHASP on a switch the Lanbon L8-HS4 . The openHASP website has listed support for other Lanbon L8 switches but not this one. This switch allows for the control of up to 4 power switches up from the previous max of 3.
I looking to change the default firmware as the support for MQTT is terrible/non existent but first want to check if this is possible before diving into the process of flashing a firmware that might not even work.
I’m afraid I never did. Looked into it but too much I’m unfamiliar with. I’d rather have a working dumb switch than a brick. I’ve hacked some stuff together in the past but also made a brick or 2 in my time.
