Openhome: Linn amp not getting an entity
Hi all,
I’m using the Linn / Openhome integration (Linn / OpenHome - Home Assistant) to discover my Linn Majik amp.
Sometimes, it would not pick up the amp, but would always recover (detect it again) on it’s own and worse case with a HA reboot.
Now, the entity is not being added (after deleting it being unavailable).
I do see some communication going on in the logs (it see’s the IP of the amp and other info), via the integration but it’s not adding a media player entity.
I also do not know how to effectively retrieve relevant information from the logs. Could anyone be of assistance?
Thanks in advance
I checked the logs with some manual setup of logging.
There are a few log entries:
INFO (SyncWorker_3) [homeassistant.loader] Loaded openhome from homeassistant.components.openhome
INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.openhome
But no further info from the openhome integration.
I did some troubleshooting using netdisco.
On my laptop, both zeroconf and sspd openhome access can be found at the IP of the amp.
Anyone have any ideas?
