Hi Barry,
This is the output of python3 -m netdisco dump
Zeroconf
[record[txt,in-unique,nas._http._tcp.local.,4500/4478.5262119140625,b'\x00'],
record[srv,in-unique,nas._http._tcp.local.,120/98.52553247070313,nas.local.:80],
192.168.1.4,
192.168.1.6,
record[txt,in-unique,snuggery:Majik DSM._http._tcp.local.,4500/4478.515046875,b'9path=/']...,
record[srv,in-unique,snuggery:Majik DSM._http._tcp.local.,120/98.51471533203124,linn-21f1cf.local.:55178],
record[ptr,in,_http._tcp.local.,4500/4478.5129375,snuggery:Majik DSM._http._tcp.local.],
record[ptr,in,_http._tcp.local.,4500/4478.520345703125,nas._http._tcp.local.]]
SSDP
GDM
LMS
Tellstick
Philips Hue N-UPnP
[('hue (192.168.1.22)', 'http://192.168.1.22:80/')]
Discovered devices:
philips_hue [('hue (192.168.1.22)', 'http://192.168.1.22:80/')]
Discovered 1 devices
As it seems the amplifier gets discovered, I also quickly shortened my home-assistant configuration to a bare minimum, set the log level to debug and got this:
-- Logs begin at Mit 2017-03-01 02:56:28 CET. --
Mar 23 22:18:33 hass hass[25010]: 17-03-23 22:18:33 INFO (MainThread) [homeassistant.components.notify] Setting up notify.pushover
Mar 23 22:18:33 hass hass[25010]: 17-03-23 22:18:33 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.openhome
Mar 23 22:18:33 hass hass[25010]: 17-03-23 22:18:33 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.kodi
Mar 23 22:18:34 hass hass[25010]: 17-03-23 22:18:34 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 14.65s
Mar 23 22:19:00 hass hass[25010]: 17-03-23 22:19:00 INFO (MainThread) [homeassistant.components.discovery] Found new service: philips_hue ('hue (192.168.1.22)', 'http://192.168.1.22:80/')
Mar 23 22:19:00 hass hass[25010]: 17-03-23 22:19:00 INFO (MainThread) [homeassistant.components.light] Setting up light.hue
Mar 23 22:21:49 hass systemd[1]: Stopping Home Assistant...
Mar 23 22:21:49 hass hass[25010]: Config directory: /opt/hass
Mar 23 22:21:50 hass systemd[1]: Stopped Home Assistant.
Mar 23 22:21:50 hass systemd[1]: Started Home Assistant.
Mar 23 22:22:00 hass hass[25283]: 17-03-23 22:22:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
Mar 23 22:22:00 hass hass[25283]: 17-03-23 22:22:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
Mar 23 22:22:00 hass hass[25283]: 17-03-23 22:22:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=toggle>
Mar 23 22:22:00 hass hass[25283]: 17-03-23 22:22:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
Mar 23 22:22:00 hass hass[25283]: 17-03-23 22:22:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=restart>
Mar 23 22:22:00 hass hass[25283]: 17-03-23 22:22:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=check_config>
Mar 23 22:22:00 hass hass[25283]: 17-03-23 22:22:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=reload_core_config>
Mar 23 22:22:01 hass hass[25283]: 17-03-23 22:22:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=persistent_notification, service=create>
Mar 23 22:22:01 hass hass[25283]: 17-03-23 22:22:01 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
Mar 23 22:22:01 hass hass[25283]: 17-03-23 22:22:01 INFO (MainThread) [homeassistant.loader] Loaded logger from homeassistant.components.logger
Mar 23 22:22:01 hass hass[25283]: 17-03-23 22:22:01 INFO (MainThread) [homeassistant.setup] Setting up logger
Mar 23 22:22:01 hass hass[25283]: 17-03-23 22:22:01 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
Mar 23 22:22:02 hass hass[25283]: 17-03-23 22:22:02 INFO (MainThread) [homeassistant.setup] Setting up recorder
Mar 23 22:22:02 hass hass[25283]: 17-03-23 22:22:02 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=logger, service=set_level>
Mar 23 22:22:02 hass hass[25283]: 17-03-23 22:22:02 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=logger>
Mar 23 22:22:04 hass hass[25283]: 17-03-23 22:22:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=recorder>
Mar 23 22:22:05 hass hass[25283]: 17-03-23 22:22:05 INFO (MainThread) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
Mar 23 22:22:05 hass hass[25283]: 17-03-23 22:22:05 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
Mar 23 22:22:05 hass hass[25283]: 17-03-23 22:22:05 INFO (MainThread) [homeassistant.loader] Loaded media_player.openhome from homeassistant.components.media_player.openhome
Mar 23 22:22:05 hass hass[25283]: 17-03-23 22:22:05 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
Mar 23 22:22:05 hass hass[25283]: 17-03-23 22:22:05 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
Mar 23 22:22:05 hass hass[25283]: 17-03-23 22:22:05 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
Mar 23 22:22:05 hass hass[25283]: 17-03-23 22:22:05 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
Mar 23 22:22:05 hass hass[25283]: 17-03-23 22:22:05 INFO (MainThread) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery
Mar 23 22:22:05 hass hass[25283]: 17-03-23 22:22:05 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater
Mar 23 22:22:05 hass hass[25283]: 17-03-23 22:22:05 INFO (MainThread) [homeassistant.setup] Setting up discovery
Mar 23 22:22:05 hass hass[25283]: 17-03-23 22:22:05 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=discovery>
Mar 23 22:22:05 hass hass[25283]: 17-03-23 22:22:05 INFO (MainThread) [homeassistant.setup] Setting up updater
Mar 23 22:22:06 hass hass[25283]: 17-03-23 22:22:06 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=updater>
Mar 23 22:22:06 hass hass[25283]: 17-03-23 22:22:06 INFO (MainThread) [homeassistant.setup] Setting up http
Mar 23 22:22:06 hass hass[25283]: 17-03-23 22:22:06 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=http>
Mar 23 22:22:06 hass hass[25283]: 17-03-23 22:22:06 INFO (MainThread) [homeassistant.setup] Setting up media_player
Mar 23 22:22:06 hass hass[25283]: 17-03-23 22:22:06 INFO (MainThread) [homeassistant.setup] Setting up history
Mar 23 22:22:06 hass hass[25283]: 17-03-23 22:22:06 INFO (MainThread) [homeassistant.setup] Setting up api
Mar 23 22:22:06 hass hass[25283]: 17-03-23 22:22:06 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
Mar 23 22:22:06 hass hass[25283]: 17-03-23 22:22:06 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=websocket_api>
Mar 23 22:22:06 hass hass[25283]: 17-03-23 22:22:06 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=history>
Mar 23 22:22:06 hass hass[25283]: 17-03-23 22:22:06 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=api>
Mar 23 22:22:06 hass hass[25283]: 17-03-23 22:22:06 INFO (MainThread) [homeassistant.setup] Setting up frontend
Mar 23 22:22:06 hass hass[25283]: 17-03-23 22:22:06 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=frontend>
Mar 23 22:22:06 hass hass[25283]: 17-03-23 22:22:06 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.openhome
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=select_source>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_up>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play_pause>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_mute>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_on>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_set>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=play_media>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_next_track>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_off>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_pause>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=clear_playlist>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_down>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_previous_track>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_seek>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_stop>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=toggle>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=media_player>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 7.17s
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Starting Home Assistant core loop
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_start[L]>
Mar 23 22:22:07 hass hass[25283]: 17-03-23 22:22:07 INFO (MainThread) [homeassistant.core] Timer:starting
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 INFO (MainThread) [homeassistant.components.http] Serving /api/websocket to 192.168.1.192 (auth: True)
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Connected
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Sending {'ha_version': '0.40.2', 'type': 'auth_ok'}
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Received {'id': 2, 'type': 'subscribe_events', 'event_type': 'state_changed'}
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Sending {'id': 2, 'type': 'result', 'result': None, 'success': True}
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Received {'id': 3, 'type': 'subscribe_events', 'event_type': 'component_loaded'}
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Sending {'id': 3, 'type': 'result', 'result': None, 'success': True}
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Received {'id': 4, 'type': 'subscribe_events', 'event_type': 'service_registered'}
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Sending {'id': 4, 'type': 'result', 'result': None, 'success': True}
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Received {'id': 5, 'type': 'get_states'}
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Sending {'id': 5, 'type': 'result', 'result': [], 'success': True}
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Received {'id': 6, 'type': 'get_config'}
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Sending {'id': 6, 'type': 'result', 'result': {'location_name': 'home', 'components': {'media_player', 'history', 'frontend', 'media_player.openhome', 'api', 'websocket_api', 'discovery', 'http', 'logger', 'updater', 'recorder'}, 'config_dir': '/opt/hass', 'version': '0.40.2', 'time_zone': 'Europe/Zurich', 'longitude': xxxxxx, 'elevation': x, 'unit_system': {'temperature': '°C', 'volume': 'L', 'mass': 'g', 'length': 'km'}, 'latitude': xxxxxx}, 'success': True}
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Received {'id': 7, 'type': 'get_panels'}
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Sending {'id': 7, 'type': 'result', 'result': {'dev-state': {'component_name': 'dev-state', 'url_path': 'dev-state', 'url': '/frontend/panels/dev-state-90f3bede9602241552ef7bb7958198c6.html'}, 'map': {'component_name': 'map', 'title': 'Map', 'url': '/frontend/panels/map-e10704a3469e44d1714eac9ed8e4b6a0.html', 'url_path': 'map', 'icon': 'mdi:account-location'}, 'dev-template': {'component_name': 'dev-template', 'url_path': 'dev-template', 'url': '/frontend/panels/dev-template-c249a4fc18a3a6994de3d6330cfe6cbb.html'}, 'dev-info': {'component_name': 'dev-info', 'url_path': 'dev-info', 'url': '/frontend/panels/dev-info-61610e015a411cfc84edd2c4d489e71d.html'}, 'history': {'component_name': 'history', 'title': 'History', 'url': '/frontend/panels/history-fdaa4d2402d49d4c8bd64a1708ab7a50.html', 'url_path': 'history', 'icon': 'mdi:poll-box'}, 'dev-service': {'component_name': 'dev-service', 'url_path': 'dev-service', 'url': '/frontend/panels/dev-service-153aad076f98bbd626466bac50986874.html'}, 'dev-event': {'component_name': 'dev-event', 'url_path': 'dev-event', 'url': '/frontend/panels/dev-event-91347dedf3b4fa9b49ccf4c0a28a03c4.html'}}, 'success': True}
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Received {'id': 8, 'type': 'get_services'}
Mar 23 22:22:09 hass hass[25283]: 17-03-23 22:22:09 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Sending {'id': 8, 'type': 'result', 'result': {'media_player': {'select_source': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entites to change source on'), ('example', 'media_player.media_player.txnr535_0009b0d81f82')])), ('source', OrderedDict([('description', 'Name of the source to switch to. Platform dependent.'), ('example', 'video1')]))]), 'description': 'Send the media player the command to change input source.'}, 'volume_up': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to turn volume up on'), ('example', 'media_player.living_room_sonos')]))]), 'description': 'Turn a media player volume up'}, 'media_play_pause': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to toggle play/pause state on'), ('example', 'media_player.living_room_sonos')]))]), 'description': 'Toggle media player play/pause state'}, 'volume_mute': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to mute'), ('example', 'media_player.living_room_sonos')])), ('is_volume_muted', OrderedDict([('description', 'True/false for mute/unmute'), ('example', True)]))]), 'description': "Mute a media player's volume"}, 'media_play': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to play on'), ('example', 'media_player.living_room_sonos')]))]), 'description': 'Send the media player the command for play.'}, 'turn_on': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to turn on'), ('example', 'media_player.living_room_chromecast')]))]), 'description': 'Turn a media player power on'}, 'volume_set': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to set volume level on'), ('example', 'media_player.living_room_sonos')])), ('volume_level', OrderedDict([('description', 'Volume level to set as flo
Mar 23 22:22:09 hass hass[25283]: at'), ('example', 0.6)]))]), 'description': "Set a media player's volume level"}, 'play_media': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to seek media on'), ('example', 'media_player.living_room_chromecast')])), ('media_content_id', OrderedDict([('description', 'The ID of the content to play. Platform dependent.'), ('example', 'https://hass.io/images/cast/splash.png')])), ('media_content_type', OrderedDict([('description', 'The type of the content to play. Must be one of MUSIC, TVSHOW, VIDEO, EPISODE, CHANNEL or PLAYLIST'), ('example', 'MUSIC')]))]), 'description': 'Send the media player the command for playing media.'}, 'media_next_track': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to send next track command to'), ('example', 'media_player.living_room_sonos')]))]), 'description': 'Send the media player the command for next track.'}, 'turn_off': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to turn off'), ('example', 'media_player.living_room_chromecast')]))]), 'description': 'Turn a media player power off'}, 'media_pause': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to pause on'), ('example', 'media_player.living_room_sonos')]))]), 'description': 'Send the media player the command for pause.'}, 'clear_playlist': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entites to change source on'), ('example', 'media_player.living_room_chromecast')]))]), 'description': 'Send the media player the command to clear players playlist.'}, 'volume_down': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to turn volume down on'), ('example', 'media_player.living_room_sonos')]))]), 'description': 'Turn a media player volume down'}, 'media_previous_track': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to send previous track command to'),
Mar 23 22:22:09 hass hass[25283]: ('example', 'media_player.living_room_sonos')]))]), 'description': 'Send the media player the command for previous track.'}, 'media_seek': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to seek media on'), ('example', 'media_player.living_room_chromecast')])), ('seek_position', OrderedDict([('description', 'Position to seek to. The format is platform dependent.'), ('example', 100)]))]), 'description': 'Send the media player the command to seek in current playing media.'}, 'media_stop': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to stop on'), ('example', 'media_player.living_room_sonos')]))]), 'description': 'Send the media player the stop command.'}, 'toggle': {'fields': OrderedDict([('entity_id', OrderedDict([('description', 'Name(s) of entities to toggle'), ('example', 'media_player.living_room_chromecast')]))]), 'description': 'Toggles a media player power state'}}, 'persistent_notification': {'create': {'fields': OrderedDict([('message', OrderedDict([('description', 'Message body of the notification. [Templates accepted]'), ('example', 'Please check your configuration.yaml.')])), ('title', OrderedDict([('description', 'Optional title for your notification. [Optional, Templates accepted]'), ('example', 'Test notification')])), ('notification_id', OrderedDict([('description', 'Target ID of the notification, will replace a notification with the same Id. [Optional]'), ('example', 1234)]))]), 'description': 'Show a notification in the frontend'}}, 'logger': {'set_level': {'fields': {}, 'description': 'Set log level for components.'}}, 'homeassistant': {'restart': {'fields': {}, 'description': ''}, 'turn_off': {'fields': {}, 'description': ''}, 'check_config': {'fields': {}, 'description': ''}, 'turn_on': {'fields': {}, 'description': ''}, 'stop': {'fields': {}, 'description': ''}, 'reload_core_config': {'fields': {}, 'description': ''}, 'toggle': {'fields': {}, 'description': ''}}}, 'success': True}
Mar 23 22:22:32 hass hass[25283]: 17-03-23 22:22:32 INFO (MainThread) [homeassistant.components.discovery] Found new service: philips_hue ('hue (192.168.1.22)', 'http://192.168.1.22:80/')
Mar 23 22:22:32 hass hass[25283]: 17-03-23 22:22:32 INFO (MainThread) [homeassistant.loader] Loaded light from homeassistant.components.light
Mar 23 22:22:32 hass hass[25283]: 17-03-23 22:22:32 INFO (MainThread) [homeassistant.setup] Setting up light
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=light, service=turn_on>
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=light, service=turn_off>
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=light, service=toggle>
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=light>
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Sending {'id': 4, 'event': {'time_fired': datetime.datetime(2017, 3, 23, 21, 22, 33, 246113, tzinfo=<UTC>), 'origin': 'LOCAL', 'event_type': 'service_registered', 'data': {'domain': 'light', 'service': 'turn_on'}}, 'type': 'event'}
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Sending {'id': 4, 'event': {'time_fired': datetime.datetime(2017, 3, 23, 21, 22, 33, 249387, tzinfo=<UTC>), 'origin': 'LOCAL', 'event_type': 'service_registered', 'data': {'domain': 'light', 'service': 'turn_off'}}, 'type': 'event'}
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Sending {'id': 4, 'event': {'time_fired': datetime.datetime(2017, 3, 23, 21, 22, 33, 252370, tzinfo=<UTC>), 'origin': 'LOCAL', 'event_type': 'service_registered', 'data': {'domain': 'light', 'service': 'toggle'}}, 'type': 'event'}
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Sending {'id': 3, 'event': {'time_fired': datetime.datetime(2017, 3, 23, 21, 22, 33, 255259, tzinfo=<UTC>), 'origin': 'LOCAL', 'event_type': 'component_loaded', 'data': {'component': 'light'}}, 'type': 'event'}
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 INFO (MainThread) [homeassistant.core] Bus:Handling <Event platform_discovered[L]: service=load_platform.light, discovered=('hue (192.168.1.22)', 'http://192.168.1.22:80/'), platform=hue>
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 INFO (MainThread) [homeassistant.loader] Loaded light.hue from homeassistant.components.light.hue
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 INFO (MainThread) [homeassistant.components.light] Setting up light.hue
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 INFO (Thread-3) [phue] Attempting to connect to the bridge...
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 INFO (Thread-3) [phue] Using ip: 192.168.1.22
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 INFO (Thread-3) [phue] Error opening config file, will attempt bridge registration
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 DEBUG (Thread-3) [phue] POST /api {"devicetype": "python_hue"}
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 WARNING (Thread-3) [homeassistant.components.light.hue] Connected to Hue at 192.168.1.22 but not registered.
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 INFO (Thread-3) [homeassistant.loader] Loaded configurator from homeassistant.components.configurator
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=configurator, service=configure>
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Sending {'id': 4, 'event': {'time_fired': datetime.datetime(2017, 3, 23, 21, 22, 33, 616894, tzinfo=<UTC>), 'origin': 'LOCAL', 'event_type': 'service_registered', 'data': {'domain': 'configurator', 'service': 'configure'}}, 'type': 'event'}
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state configurator.philips_hue=configure; fields=[], description_image=/static/images/config_philips_hue.jpg, entity_picture=/static/images/logo_philips_hue.png, configure_id=2830274928-1, submit_caption=I have pressed the button, description=Press the button on the bridge to register Philips Hue with Home Assistant., friendly_name=Philips Hue @ 2017-03-23T22:22:33.631588+01:00>, old_state=None, entity_id=configurator.philips_hue>
Mar 23 22:22:33 hass hass[25283]: 17-03-23 22:22:33 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 2923197040: Sending {'id': 2, 'event': {'time_fired': datetime.datetime(2017, 3, 23, 21, 22, 33, 631874, tzinfo=<UTC>), 'origin': 'LOCAL', 'event_type': 'state_changed', 'data': {'entity_id': 'configurator.philips_hue', 'old_state': None, 'new_state': <state configurator.philips_hue=configure; fields=[], description_image=/static/images/config_philips_hue.jpg, entity_picture=/static/images/logo_philips_hue.png, configure_id=2830274928-1, submit_caption=I have pressed the button, description=Press the button on the bridge to register Philips Hue with Home Assistant., friendly_name=Philips Hue @ 2017-03-23T22:22:33.631588+01:00>}}, 'type': 'event'}
So with this config the only entity I’m seeing in the “states” developer tool is the hue bridge, but no mediaplayer.snuggery or similar. Or am I doing something wrong?
I’m running Davaar 4.54.135.
Thanks a lot,
Benjamin
