Opening curtains after Android and iOS alarm clocks
The automation will be good for you and probably won’t need any tweaking,
If one person in your pair has Android and the other has iOS.
Description
When the alarm rings, the automation checks to see if your partner is home.
If your partner is not home, it opens the curtains.
If your partner is home, the automation will wait for their alarm clock to go off (but no more than 3 hours).
As soon as the partner’s alarm rings, the curtains are opened.
I propose to add an additional restriction that the automation will not start more than once every 10 hours.
This would be handy if, after the alarm, you want to close the curtains and sleep some more,
but forget to turn off the next alarm - without the proposed restriction, the curtains might open again and you’d be pissed.
I sometimes use alarms in the evening as well, so I add a time condition: 08:00 to 12:30 in the morning.
So the automation doesn’t trigger falsely and open my blinds in the evening.
The Home Assistant app must be installed on Android and iOS, must be logged in to the server.
Requirements
You must have home presence trackers set up for your person
objects.
This is needed so that when your partner is not home, the curtains will open without waiting for their alarm clock.
Creating automation
Auxiliary Object
Create a button (input_button.alarm_stopped
) in Home Assistant. This button will be pressed by iphone when alarm is stopped.
You can name it anything you like, for example “iOS alarm_stopped”.
Creating automation in the “Commands” application
- Install and open the Commands app on your iphone
- Go to the “Automation” tab
- Select “Create automation for yourself.”
- Select “Alarm Clock”, check “Stopped”, “Any”, press “Next”
- Press “Add Action”, search for “Home Assistant”, select “Call Service”.
- Press on “Service”, choose
input_button.press
from the list that appears. - Click on the arrow after “with data”, select your Home Assistant server
- Enter `{“entity_id”: “input_button.alarm_stopped”} in the “Service Data” field.
- Make sure that the “Show on startup” toggle is disabled
- Click “Next.”
- Remove the “Ask before startup” toggle, confirm it with “Don’t ask” in the dialog box that appears
- Click on “Done”.
Enable access to the alarm clock on Android
- Open the Home Assistant app
- Press “Settings”, select “Mobile App”, go to “Sensor Management”
- Find “Next alarm” in the list, tap on that sensor
- Make sure the “Enable Sensor” toggle is on, turn it on if necessary
Creating HomeAssistant Automation
Instead of automation.cover_open_on_alarm_clock
write the name of your automation.
You will be able to find it out or change it after the first save of your automation.
Replace the sensor sensor.android_next_alarm
with yours.
You can find out its name by opening the page of your android device and selecting the sensor “Next Alarm”.
alias: Open curtains after Android and iOS alarms
description: >-
Opens curtains when 2 alarms have been stopped between 08:00 and 12:30
There is an automation set up on the iPhone that triggers the push button service,
checks who pressed it.
On android it looks to see if there is < 30 seconds left to the alarm.
- platform: state
entity_id:
- input_button.alarm_stopped
alias: When the ios alarm was stoppe
value_template: >
{{ state_attr('sensor.android_next_alarm', 'Time in Milliseconds') !=
None and state_attr('sensor.android_next_alarm', 'Time in
Milliseconds') / 1000 - as_timestamp(now()) < 30}}
alias: When the android alarm rings after 30 seconds
condition:
- condition: time
after: "08:00:00"
before: "12:30:00"
weekday:
- sun
- sat
- fri
- thu
- wed
- tue
- mon
alias: Time 08:00-12:30
enabled: true
- condition: template
value_template: >-
{{(as_timestamp(now()) -
as_timestamp(state_attr("automation.cover_open_on_alarm_clock",
"last_triggered") | default(0)) | int > 10 * 60 * 60 )}}
alias: Last triggered more than 10 hours ago
enabled: true
- if:
- condition: trigger
then:
- choose:
- conditions:
- condition: state
entity_id: person.android
state: home
alias: Android at home
sequence:
- wait_for_trigger:
value_template: >
Milliseconds') != None and
alias: Alarm on android rings in less than 30 seconds
timeout:
hours: 3
minutes: 0
seconds: 0
milliseconds: 0
alias: Wait for android's alarm clock
continue_on_timeout: false
- service: cover.open_cover
data: {}
entity_id: cover.curtain_bedroom
alias: Open the curtains
alias: If android is home, we wait for his alarm
default:
data: {}
alias: Wait for android alarm if android is home + open
alias: If triggered by ios, wait for android alarm to approach
- if:
then:
- choose:
- conditions:
- condition: state
entity_id: person.iphone
state: home
alias: Iphone at home
sequence:
- wait_for_trigger:
- platform: state
entity_id:
alias: When the alarm was stopped
timeout:
hours: 3
minutes: 0
seconds: 0
milliseconds: 0
alias: Wait for iphone's alarm clock
data: {}
default:
data: {}
alias: Wait for ios alarm if iphone is home + open
alias: If android triggered, wait for ios alarm to stop
mode: single
You can modify the automation to suit your needs, for example, determine who pressed the button and act on it.
Checks if user admin
pressed the button.
value_template for the trigger
value_template: >-
{% set andrew_id = states.person.admin.attributes.user_id
{% set nastya_id = states.person.nastya.attributes.user_id
{% set who_stopped_id =
states.input_button.alarm_stopped.context.user_id %}
{% set andrew_stopped = who_stopped_id == andrew_id %}
{{ andrew_stopped }}
I will be glad if automation takes root in your home.
