Opening sensor card displays "no statistics found" instead of graph
I have a sensor that in itself works, but if I open the sensor card (from entities) then I get the sensor card but it displays “no statistics found” instead of the graph that I would expect.
If i click on show more, then i am led to the history page and I do get the full history graph of this sensor.
The value of the sensor is displayed in the card, so the sensor works.
Anyone can help me with what might be wrong?
In the developer tools / statistics I finally found an error with regards to this sensor and a notification that the statistics unit had changed.
I did the ‘fix issue’ and selected to also remove all history. The graph is now completely empty, but a graph does popup. So i’ll wait a day to see if it populates and fixed the issue.
I had the same issue but I chose to keep the old data when applying the fix and I still get “No statistics found”. Since the fix is now gone I can’t even apply it with deleting the data.
After the entity changed its value, the graph has now appeared.
