Hello everyone…
Not sure what happened or if it was a recent update from OMV, but all the sudden i dont see any disk or whatsnot info anymore…
Does this happen to anyone else so far?
Thx for ideas…
Debug logging is enabled
will see what i can find in it
right now it just says : unable to fetch data (500)
@Darkyputz how did you end up solving this issue? I have the same problem with one of my systems after upgrading to 1.4.2 where it was previously working fine. I have a second system also running 1.4.2 and it’s fine. But on the first system, and also if I add monitoring for first system on the second, it sets up the integration, but all of the sensors are unknown. Using debug on it I see OpenMediaVault 192.168.1.xxx unable to fetch data (500) in the logs.
So it seems this is more of an OMV issue than an HA issue.
Oh i am so sorry, i did not see your response.
I ended up following the tip from the original writer of the plugin.
Using the base version and nothing newer than that.
I normally aim for the newest stuff, but here it did not work. so deleting and reinstalling base version did the trick. Hope you get that fixed this way as well
