Openplantbook : ... is not a valid add-on repository
hello,
I’m trying to add openplantbook as a custom repository in my add-on menu, but get following error :
GitHub - Olen/home-assistant-openplantbook: Integration to search and fetch data from Openplantbook.io is not a valid add-on repository”
I use a supervised version :
Home Assistant 2023.10.1
Supervisor 2023.10.0
Operating System 10.5
Frontend 20231005.0 - latest
Because that’s not an add-on, but an integration
When the docs there refer to HACS they mean https://hacs.xyz/
It’s an integration, not an add-on.
See Tips and Tricks | Home Assistant Developer Docs on how to add custom integrations.
ok,
I understand now that this is not an add-on.
In the instructions it says the following :
  • Click HACS in your Home Assistnat
  • Click Integrations
  • Click the 3 dots in the top right corner and select “Custom Repositories”
  • Add the URL to this github repository and category “Integration”
But I do not find the HACS in my home assistant, so this means I do not have the correct HA installed?
if so this means I have to add it manually?
If I have to add it manually it says :
  • Copy the wholecustom_components/openplantbook/ directory to your server’s <config>/custom_components directory
but under my config directory I do not see the “custom_components” directory :frowning:
Please help this newby setup this integration please :slight_smile:
You need to install hacs https://hacs.xyz/
Because, as has been said already, you have to install HACS.
You can create it you know :wink:
thanks
I’ll get started with installing HACS first.
I thought with all the different HA installations you do not have the ability to use HACS or add “custom_components” if it doesn’t exist as a directory
:slight_smile:
ok,
I finally got HACS installed and I was able to install the OpenPlantBook.
But now it says that I should open the configuration of the OpenPlantbook, but I do not find this page anywhere.
Any help is apreciated :slight_smile:
You read https://github.com/Olen/home-assistant-openplantbook#set-up?
Yes and that is indeed the step in where I’m stuck.
I do not find that panel.
What panel?
I mean this one : options openplantbook
Edit : found the solution. After installation I still needed to add the integration :
“Settings” → “Devices and services” and click “Add integration”.
Search for “Plant” to set up a new plant
After this I saw the options panel
