Opensprinkler running on same RPI as Hassio
I have multiple instances of HA mostly ruinning on RPI. I have now successfully migrated my config from HA to Hassio on my Pi zero and would now like to do the same on my RPI3. However I also run opensprinkler on the RPI3.
It may be a stupid question, but am I able to run both Hassio and opensprinkler on the same RPI3?
Thanks for any help you are able to provide
Hi uiguy,
Yes you can! I did this for a couple of months by using the generic Linux installer.
Last week I moved over to the full Hassio SD-card image and created an add-on to run OpenSprinkler. Working perfectly!
You can test and install it by adding this repository: https://github.com/stefanlaheij/hassio-addons
