I have the OpenTherm gateway with firmware V6.5 connected over ethernet to home assistant.
I use the thermostat Honeywell TH8210M1003.
I have an issue that the comfort mode of DHW is on after a restart of the thermostat/OTGW. It means that sometimes the boiler is switching on to keep DWH on temperature and I wonder if it is possible to switch it off from home assistant.
