I have a problem with the new Opentherm Gateway component. I think i did everyting right but all I get is an error in the logbook. No entity shows up in HomeAssistant…
I have a NodeMCU with ESPEasy firmware connected to the Opentherm Gateway. When I telnet to the nodeMCU serial port or use OTMonitor all works fine.
018-09-19 13:55:54 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 342, in _async_add_entity
await entity.async_added_to_hass()
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/climate/opentherm_gw.py", line 66, in async_added_to_hass
await self.gateway.connect(self.hass.loop, self._device)
File "/usr/local/lib/python3.6/site-packages/pyotgw/pyotgw.py", line 55, in connect
await self.get_reports()
File "/usr/local/lib/python3.6/site-packages/pyotgw/pyotgw.py", line 170, in get_reports
OTGW_DEFAULT_TIMEOUT, loop=self.loop)
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 362, in wait_for
raise futures.TimeoutError()
concurrent.futures._base.TimeoutError
Same here, after a reboot of Home-Assistant it works for a short period, after that it crashes.
File "/usr/src/app/homeassistant/helpers/service.py", line 226, in _handle_service_platform_call
await func(entity, data)
File "/usr/src/app/homeassistant/components/climate/__init__.py", line 679, in async_service_temperature_set
await entity.async_set_temperature(**kwargs)
File "/usr/src/app/homeassistant/components/climate/opentherm_gw.py", line 174, in async_set_temperature
temp)
File "/usr/local/lib/python3.6/site-packages/pyotgw/pyotgw.py", line 91, in set_target_temp
self._protocol.issue_cmd(cmd, value), timeout, loop=self.loop))
Also anoying: not after every reboot the component is loaded. Home-Assistant complains that it takes too long to load or anything. And the only way to get it running is to reboot Home-Assistant again.
I’ve upgraded my NodeMCU with ESPEasy firmware to the newest version (MEGA 20183010) and changed/tested a lot of settings… Now suddently everything works. It runs stable for a couple of hours now…
can some body help me to get the opentherm gateway working with home assistant?
i’m now struggling for 6 months with different versions of H.A. and always get the same error after a reboot of H.A.
"Invalid config
The following components and platforms could not be set up:
i have tried different yaml configs and H.A. versions (now 100.3) and always get the same error.
my gateway is working, when i connect with telnet i get sensor data in the telnet window.
it has always worked in domoticz with the same config in the gateway.
this is a section of my current configuration.yaml:
logger:
default: debug
logs:
homeassistant.components.opentherm_gw: info
homeassistant.components.climate: info
