OpenTherm Gateway: configure modes and presets
I bought the nodoshop opentherm gateway (otgw) and set it up with the wired lan connection and used the home assistant opentherm gateway integration.
For learning and pleasure i enabled all 175 entities to see what the gateway can read and write to the central heater.
I have the thermostat card enabled in lovelace but am unable to setup a mode or preset. is there a possibility to create modes and presets?
Furthermore, is there anyone who has experience with using other temperature sensors as imput for room temperature using the opentherm gateway integration?
In the end, i would like to have my different room temp sensors in a group as group temp sensor as input for the room temp and use a zigbee thermostat device to ‘scroll’ to the desired temp and use that as desired room temp.
Any help would be appreciated.
