I bought a Home Assistant Green and a couple of ZBT-1 (one for thread, one for Zigbee as apparently the dual mode doesn’t work)
However for two days I’ve struggled to get them working properly.
I added the ZBT-1 and selected the ZIgbe and Thread firmware on each
however I get numerous errors, particularly regarding thread:
Home Assistant Connect ZBT-1 (OpenThread Border Router)
No devices or entities
Failed setup, will retry: Unable to connect
I’ve tried disabling Open Thread Border Router and restarting home assistant. Physically unplugging and reconnecting the ZBT-1.
For a while I struggled to discover the ZBT-1, they’d show up I’d go to add, they’d fail then disappear. Sometimes I’d get errors about being unable to determine the radio. I found this post and followed the steps there and managed to finally get the ZBT-1s to add but and still stuck in this error state.
wmaker
(Tommy Long)
May 24, 2025, 5:51pm
2
Maybe show the logs for the OTBR AddOn.
hmm i dont see any logs in the /config/integrations/integration/otbr page
I have an enable debug logging option but if I press it I still see no logs on the screen
how do i get to that page? i cant see how to get to that screen in homeassistant
francisp
(Francis)
May 27, 2025, 10:49am
6
Settings → Add-ons → OpenThread Border Router
ah! thanks.
[13:36:46] INFO: The otbr-web is disabled.
s6-rc: info: service mdns: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service mdns successfully started
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service banner: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
[13:36:47] INFO: Starting mDNS Responder...
Default: mDNSResponder (Engineering Build) (Jan 14 2025 21:08:25) starting
Add-on: OpenThread Border Router
OpenThread Border Router add-on
Add-on version: 2.13.0
You are running the latest version of this add-on.
System: Home Assistant OS 15.2 (aarch64 / green)
Home Assistant Core: 2025.5.2
Home Assistant Supervisor: 2025.05.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service universal-silabs-flasher: starting
[13:36:51] INFO: Checking /dev/ttyUSB0 identifying Home Assistant Connect ZBT-1 from Nabu Casa.
[13:36:51] INFO: Starting universal-silabs-flasher with /dev/ttyUSB0
2025-05-23 13:36:54.766 homeassistant universal_silabs_flasher.flash INFO Extracted GBL metadata: NabuCasaMetadata(metadata_version=2, sdk_version='4.4.4', ezsp_version=None, ot_rcp_version='SL-OPENTHREAD/2.4.4.0_GitHub-7074a43e4' (2.4.4.0), cpc_version=None, fw_type=<FirmwareImageType.OPENTHREAD_RCP: 'openthread_rcp'>, fw_variant=None, baudrate=460800)
2025-05-23 13:36:54.767 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2025-05-23 13:36:56.804 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.SPINEL at 460800 baud
2025-05-23 13:37:01.148 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.CPC at 460800 baud
2025-05-23 13:37:05.492 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.CPC at 115200 baud
2025-05-23 13:37:09.836 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.CPC at 230400 baud
2025-05-23 13:37:14.179 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.EZSP at 115200 baud
2025-05-23 13:37:15.358 homeassistant universal_silabs_flasher.flasher INFO Detected ApplicationType.EZSP, version '7.1.1.0 build 273' (7.1.1.0.273) at 115200 baudrate (bootloader baudrate None)
2025-05-23 13:37:15.359 homeassistant universal_silabs_flasher.flash INFO Cross-flashing from FirmwareImageType.ZIGBEE_NCP to FirmwareImageType.OPENTHREAD_RCP
2025-05-23 13:37:21.508 homeassistant universal_silabs_flasher.flasher INFO Probing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2025-05-23 13:37:21.560 homeassistant universal_silabs_flasher.flasher INFO Detected bootloader version '2.1.1'
2025-05-23 13:37:21.561 homeassistant universal_silabs_flasher.flasher INFO Detected ApplicationType.GECKO_BOOTLOADER, version '2.1.1' at 115200 baudrate (bootloader baudrate 115200)
skyconnect_openthread_rcp_2.4.4.0_GitHub-7074a43e4_gsdk_4.4.4.gbl
s6-rc: info: service universal-silabs-flasher successfully started
s6-rc: info: service otbr-agent: starting
[13:37:44] INFO: Setup OTBR firewall...
[13:37:45] INFO: Starting otbr-agent...
[NOTE]-AGENT---: Running 0.3.0-b067e5ac-dirty
[NOTE]-AGENT---: Thread version: 1.3.0
[NOTE]-AGENT---: Thread interface: wpan0
[NOTE]-AGENT---: Radio URL: spinel+hdlc+uart:///dev/ttyUSB0?uart-baudrate=460800&uart-flow-control
[NOTE]-AGENT---: Radio URL: trel://end0
[NOTE]-ILS-----: Infra link selected: end0
49d.17:07:42.763 [C] P-SpinelDrive-: Software reset co-processor successfully
00:00:00.037 [N] RoutingManager: No valid /48 BR ULA prefix found in settings, generating new one
00:00:00.042 [N] RoutingManager: BR ULA prefix: fdc8:45c:17ea::/48 (generated)
00:00:00.042 [N] RoutingManager: Local on-link prefix: fdde:ad00:beef:cafe::/64
00:00:00.082 [W] P-Netif-------: Failed to process request#2: No such process
s6-rc: info: service otbr-agent successfully started
s6-rc: info: service otbr-agent-configure: starting
Done
00:00:00.649 [W] P-Daemon------: Daemon read: Connection reset by peer
s6-rc: info: service otbr-agent-configure successfully started
s6-rc: info: service otbr-agent-rest-discovery: starting
00:00:02.636 [N] RoutingManager: Local on-link prefix: fd9a:8474:822:bfd5::/64
00:00:02.655 [N] Mle-----------: Role disabled -> detached
00:00:02.667 [N] P-Netif-------: Changing interface state to up.
00:00:02.689 [W] P-Netif-------: Failed to process request#5: No such process
00:00:03.054 [N] Mle-----------: Attach attempt 1, AnyPartition reattaching with Active Dataset
[13:37:49] INFO: Successfully sent discovery information to Home Assistant.
s6-rc: info: service otbr-agent-rest-discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
00:00:09.554 [N] RouterTable---: Allocate router id 1
00:00:09.554 [N] Mle-----------: RLOC16 fffe -> 0400
00:00:09.558 [N] Mle-----------: Role detached -> leader
00:00:09.558 [N] Mle-----------: Partition ID 0x6225b346
[NOTE]-BBA-----: BackboneAgent: Backbone Router becomes Primary!
00:00:11.228 [W] DuaManager----: Failed to perform next registration: NotFound
00:24:50.367 [W] P-RadioSpinel-: Unexpected Spinel transaction message: 3
00:24:50.367 [W] P-RadioSpinel-: Error processing response: Drop
00:24:50.983 [W] P-RadioSpinel-: radio tx timeout
00:24:50.983 [W] P-RadioSpinel-: RCP failure detected
00:24:50.983 [W] P-RadioSpinel-: Trying to recover (1/2)
00:24:51.018 [N] P-RadioSpinel-: RCP recovery is done
00:25:11.091 [W] P-RadioSpinel-: Unexpected Spinel transaction message: 3
00:25:11.091 [W] P-RadioSpinel-: Error processing response: Drop
00:25:11.938 [W] P-RadioSpinel-: radio tx timeout
00:25:11.938 [W] P-RadioSpinel-: RCP failure detected
00:25:11.938 [W] P-RadioSpinel-: Trying to recover (1/2)
00:25:11.973 [N] P-RadioSpinel-: RCP recovery is done
00:25:12.189 [W] P-RadioSpinel-: Unexpected Spinel transaction message: 3
00:25:12.189 [W] P-RadioSpinel-: Error processing response: Drop
01:38:19.347 [W] P-HdlcIntface-: Error decoding hdlc frame: Parse
01:38:19.349 [W] P-RadioSpinel-: Unexpected Spinel transaction message: 3
01:38:19.349 [W] P-RadioSpinel-: Error processing response: Drop
01:38:20.451 [W] P-RadioSpinel-: Unexpected Spinel transaction message: 3
01:38:20.451 [W] P-RadioSpinel-: Error processing response: Drop
01:38:21.553 [W] P-RadioSpinel-: Unexpected Spinel transaction message: 3
01:38:21.553 [W] P-RadioSpinel-: Error processing response: Drop
Default: mDNSPlatformSendUDP got error 99 (Cannot assign requested address) sending packet to ff02::fb on interface fe80::9c34:22ff:fe73:7702/veth23f0dff/12
Default: mDNSPlatformSendUDP got error 99 (Cannot assign requested address) sending packet to ff02::fb on interface fe80::6084:ddff:fe24:a908/veth975fa3c/13
Default: mDNSPlatformSendUDP got error 99 (Cannot assign requested address) sending packet to ff02::fb on interface fe80::905f:37ff:fe9f:942f/vethd4543f9/14
05:43:27.977 [W] P-RadioSpinel-: radio tx timeout
05:43:27.977 [W] P-RadioSpinel-: RCP failure detected
05:43:27.977 [W] P-RadioSpinel-: Trying to recover (1/2)
05:43:28.346 [W] P-RadioSpinel-: Unexpected Spinel transaction message: 3
05:43:28.346 [W] P-RadioSpinel-: Error processing response: Drop
05:43:29.444 [W] P-RadioSpinel-: Unexpected Spinel transaction message: 3
05:43:29.444 [W] P-RadioSpinel-: Error processing response: Drop
05:43:29.977 [W] P-RadioSpinel-: Wait for response timeout
05:43:29.977 [W] P-RadioSpinel-: RCP failure detected
05:43:29.977 [W] P-RadioSpinel-: Trying to recover (2/2)
05:43:30.009 [N] P-RadioSpinel-: RCP recovery is done
05:43:30.039 [N] P-RadioSpinel-: RCP recovery is done
05:43:30.546 [W] P-HdlcIntface-: Error decoding hdlc frame: Parse
05:43:31.649 [W] P-RadioSpinel-: Unexpected Spinel transaction message: 3
05:43:31.649 [W] P-RadioSpinel-: Error processing response: Drop
05:43:49.216 [W] P-RadioSpinel-: radio tx timeout
05:43:49.216 [W] P-RadioSpinel-: RCP failure detected
05:43:49.216 [W] P-RadioSpinel-: Trying to recover (1/2)
05:43:51.218 [W] P-RadioSpinel-: Wait for response timeout
05:43:51.218 [W] P-RadioSpinel-: RCP failure detected
05:43:51.218 [W] P-RadioSpinel-: Trying to recover (2/2)
05:43:53.220 [W] P-RadioSpinel-: Wait for response timeout
05:43:53.220 [W] P-RadioSpinel-: RCP failure detected
05:43:53.221 [C] P-RadioSpinel-: Too many rcp failures, exiting
05:43:53.221 [C] Platform------: RecoverFromRcpFailure() at radio_spinel.cpp:2063: Failure
[19:21:39] WARNING: otbr-agent exited with code 1 (by signal 0).
Chain OTBR_FORWARD_INGRESS (0 references)
target prot opt source destination
DROP all -- anywhere anywhere PKTTYPE = unicast
DROP all -- anywhere anywhere match-set otbr-ingress-deny-src src
ACCEPT all -- anywhere anywhere match-set otbr-ingress-allow-dst dst
otbr-ingress-deny-src-swap
otbr-ingress-allow-dst-swap
Chain OTBR_FORWARD_EGRESS (0 references)
[19:21:40] INFO: OTBR firewall teardown completed.
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service otbr-agent-rest-discovery: stopping
s6-rc: info: service otbr-agent-rest-discovery successfully stopped
s6-rc: info: service otbr-agent-configure: stopping
s6-rc: info: service otbr-agent-configure successfully stopped
s6-rc: info: service otbr-agent: stopping
s6-rc: info: service otbr-agent successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service universal-silabs-flasher: stopping
s6-rc: info: service mdns: stopping
Default: mDNSResponder (Engineering Build) (Jan 14 2025 21:08:25) stopping
s6-rc: info: service universal-silabs-flasher successfully stopped
s6-rc: info: service banner: stopping
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
[19:21:40] INFO: mDNS ended with exit code 4 (signal 0)...
s6-rc: info: service mdns successfully stopped
wmaker
(Tommy Long)
May 27, 2025, 6:19pm
8
Looks like the OTBR reflashed the ZBT-1 with Thread firmware, but now the OTBR and ZBT-1 aren’t communicating very well. Perhaps, stop the OTBR AddON, unplug the ZBT-1, wait a minute, plug in the ZBT-1 and then start the OTBR AddOn and see what the logs show.
If it is still failing, try configuring the OTBR’s baud rate to 460800
This seems to have fixed it. Although unplugging and replugging the ZBT-1s was one of the first things I tried, but this time I restarted Home Assistant before replugging in.
Cheers
