Hi all
I have a very well working setup of HA on Ubuntu 18.04 .
Now I installed OpenVPN client to be able to use my powerful NUC also as a torrentbox with openvpn+qbittorrent. Its working, qbittorrent is only using VPN network interface (tun0) and Chrome is using VPN through tun0 with no problem. Everything is autostarting correctly when NUC is restarted.
Problem is when OpenVPN client is activated (autostart and always on is my wish) , HA seems to have trouble co-existing with VPN setup. The following components seems to be at fault:
- duckdns/letsencrypt (i cant access from outside or domain)
- sonos/media player discovery problem. No connection to media players/sonos on local network
- xiaomi integration not able to use/start (no major problem, i can get rid of it and use only deconz)
- I think that some location tracking also fails, especially google map tracking
I have ethernet network interface to the NUC (enu0) with same IP as before, that way i can access HA on local net by local IP-adress, but not through internet (duckdns).
I was digging into forums how to force HA and related processes to use non-VPN interface for both incoming, outgoing and discovery/integrations, but I could not understand how to do that (“ip netds” method???) and I was thinking I may be going the wrong way
Any ideas of how to force HA and related processes to only use non-VPN network interface is very welcome
