I have a problem updating the new openwakeword addon. It just says this:
Failed to call service update/install. Error updating openWakeWord:
Can't install homeassistant/armv7-addon-openwakeword:1.8.0:
404 Client Error for http+docker://localhost/v1.43/images/create?tag=1.8.0& fromlmage=homeassistant%2Farmv7-addon-openwakeword&platform=linux%2Farm64:
Not Found ("pull access denied for homeassistant/armv7-addon-openwakeword,
repository does not exist or may require docker login: denied: requested access
to the resource is denied")
Having the same problem when trying to install the addon:
Can't install homeassistant/armv7-addon-openwakeword:1.8.1: 404 Client Error for http+docker://localhost/v1.42/images/create?tag=1.8.1&fromImage=homeassistant%2Farmv7-addon-openwakeword&platform=linux%2Farm%2Fv7: Not Found ("pull access denied for homeassistant/armv7-addon-openwakeword, repository does not exist or may require 'docker login': denied: requested access to the resource is denied")
No time to investigate yet, running Home Assistant Supervised
Update: After installing a update for Supervisor (2023.10.1), it worked
