Hi all!
I’m trying to figure out a way to check when it’s sunny or partlycloudy for Shelly Plug which switches AC power off to my Ecoflow River2 Max via AC so that it can charge via solar panels instead and turn on when let’s say battery of Ecoflow River2 max is under 15% and it’s a bad weather, cloudy, rainy, snowing…
Sure, another way would be to install Shelly 1PM Plus on solar panels and monitor the solar power, but I might do that later if this won’t function well…
Problem is that Ecoflow River2 Max can’t simultaneously charge via AC and solar. And I can’t monitor solar power when AC power is on.
Right now this is my config:
alias: forecast solar ON sunny
description: ""
- platform: time_pattern
minutes: /10
condition: []
- if:
- condition: and
conditions:
- condition: numeric_state
entity_id: sensor.openweathermap_cloud_coverage
above: 0
below: 70
- type: is_battery_level
condition: device
device_id: someid
entity_id: sensor.river2max_main_battery_level
domain: sensor
above: 16
then:
- type: turn_off
device_id: someid
entity_id: switch.shellyplug_s_80646f81671a
domain: switch
else:
- type: turn_on
device_id: someid
domain: switch
mode: single
Problem is that this automation turns ON shelly for some reason…
Thanks a lot!
