I have recently installed the OpenWeatherMap integration (v3.0). If I now open the service I see that by default forecast sensors are available (e.g. “Forecast Precipitation” = 1.44 mm or “Forecast Precipitation probability” = 100%).
Do you know what the default forecast time period is which is used for this? I see another sensor called “Forecast Time” = 3 hours go, which I guess is the time when the last forecast was retrieved. But I cannot see for which time period the forecast is valid for. E.g. Forecast for the next 12 hours, 24 hours…
Thanks!
