OpenWeatherMap forecast values as entities?
Hello in order to get a weather forecast on my nextion display with esp-home i want to get the forecast values in Homeassistant.
Out of the box with the OpenWeatherMap integration there are coming values like: sensor.openweathermap_forecast_temperature
But this seams to be only the forecast for the current day or next 24h
Want i need are forecast for the next 5 days like:
sensor.openweathermap_forecast_temperature_monday
But how is the best way to get forecast values in HomeAssistat as entities?
I think this can be handled with an api call to openweathermap. But how do i integrate this in Homeasstant?
Probably you can give me some hints in which direction i should go and where i can set this up in HA.
Many thanks in advance
Best
Isn’t the forecast in the weather entity?
You should be able to get it with template sensors:
    sensors:
      forecast_1:
        value_template: {{ state_attr('weather.xxx', 'forecast')[1].temperature }}
Hi many thanks yes there is a forecast entity but not one for each day.
May i just ask the question where i should add the sensor ? In the config.yaml?
Many thanks in advance for your help
Yes in your configuration under the sensor “tag”
Documentation for template sensor is here:
Hm. What is “weather.xxx”?
Isn’t the name of it sensor.openweather”?
