I have an API key for OpenWeatherMap, but when trying to add the integration, it just shows an empty popup (and nothing is added).
Any help is appreciated
Which mode are you using? I use once all_daily and it works fine.
I think the ‘onecall_hourly’ and ‘onecall_daily’ are the recommended ones.
onecall_hourly seems to work. Thanks!
glad you got it sorted!
Hi @DeckardCain2014, welcome to the forum and good your problem got solved!
Please take the time to mark the answer as solution, you do that by selecting the three dots under the post:
Then select the check box:
This can be useful to other users as well.
Don’t forget too while you’re down there to click the heart to like the post, as a way of saying thank you.
Hi @Nick4 ,
I would really like to mark it as an answer, but neither mobile nor on my desktop computer I can mark it as a solution.
