banzaay
February 18, 2020, 11:33am
1
I have configured OpenweatherMap in configuration.yaml in this way:
- platform: openweathermap
api_key: <xxxxxxx>
monitored_conditions:
- weather
- temperature
- wind_speed
- humidity
- pressure
- clouds
Then in automations.yaml I creted a simple automation:
- alias: 'Check Temperature'
entity_id: sensor.temperature
below: 10
conditions:
- condition: time
after: '8:00'
before: '20:00'
service: system_log.write
data_template:
message: 'Temperature changed {{states(sensor.temperature)}}.'
level: info
When I restart Homeassitant I got this error:
2020-02-18 12:23:47 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: Invalid platform specified @ data['trigger'][0]. Got None
extra keys not allowed @ data['conditions']. Got None. (See /home/homeassistant/.homeassistant/configuration.yaml, line 13). Please check the docs at https://home-assistant.io/integrations/automation/
If I comment the automation no error is displayed.
Can you help me ?
Thanks & Bye
Mirko
VDRainer
February 18, 2020, 11:37am
2
There’s no trigger platform openweathermap.
I think you’re looking for the numeric_state trigger
EDIT: Also conditions should be condition
EDIT 2:
And the message template will not work this way.
Should be:
message: "Temperature changed {{states('sensor.temperature')}}."
Hi
I have configured an email with the information about the weather
- alias: 'Send mail message at a given time'
platform: time_pattern
hours: "/1"
- service: notify.MailMirko
title: "Homeassistant test mail"
message: "TEST TEST!! \nTemperature {{states('weather.temperature')}} \nWeather {{states('weather.weather')}} \nWind_speed {{states('sensor.wind_speed')}} \nHumidity {{states('sensor.humidity')}} \nPressure {{states('sensor.pressure')}} \nClouds {{states('sensor.clouds')}}."
- service: system_log.write
data_template:
message: "Homeassistant test mail Temperature {{states('sensor.temperature')}}"
level: info
But I receive email wihtout data:
TEST TEST!!
Temperature unknown
Weather unknown
Wind_speed unknown
Humidity unknown
Pressure unknown
Clouds unknown.
In the UI I can see all the information correctly.
What is the problem ?
(Taras)
March 27, 2020, 2:02pm
5
Change the first data: to data_template: and correct the indentation.
I have changed data: to data_templete: but nothig.
The mail is sent but with unknown Temperature.
What is the problem of my indentation ?
I still can’t get this information visible in my email.
Can someone help me ?
ZombiEd
(Edward Omiccioli)
June 10, 2020, 5:09pm
8
Did you ever resolve your problem? Here is a simple one that I did using openweather map to be notified of a High Temp. It works perfectly.
alias: High Temperature
description: ''
- above: '89'
entity_id: sensor.owm_temperature
platform: numeric_state
condition: []
- data:
message: Temp at {{ states.sensor.owm_temperature.state }} degrees.
title: High Temp
service: notify.mobile_app_eds_iphonetype or paste code here
