OpenWindow Automation
I’m new to HA.
One of my automations has a bad behavior and I cant’t explain it to me.
I have two thermostats and two windoswitches in my room via ziggbee2mqtt.
If the window is opend and it is below 16°C the thermostats have to change to openwindow_on.
If both switches are closed the openwindow changes to off and an automation is triggered to select the temperature in the shedule.
The first step works fine but after 1 second the state of thermostat 2 changes back. The log says it is triggerd by switch 1. But this wasen’t defined.
What can I do?
alias: WOZI_openwindow
description: ""
  - platform: state
    entity_id:
      - binary_sensor.schalter_1_contact
      - binary_sensor.schalter_2_contact
    for:
      hours: 0
      minutes: 0
      seconds: 30
condition:
  - condition: numeric_state
    entity_id: weather.openweathermap
    attribute: temperature
    below: 16
  - choose:
      - conditions:
          - condition: or
            conditions:
              - condition: state
                entity_id: binary_sensor.schalter_1_contact
                state: "on"
              - condition: state
                entity_id: binary_sensor.schalter_2_contact
                state: "on"
        sequence:
          - type: turn_on
            device_id: ade355b2f765de16dacf35443dbebabb
            entity_id: switch.wozi_thermostat_1_open_window
            domain: switch
          - type: turn_on
            device_id: 833efe512fe9983fce4796f1ebd451db
            entity_id: switch.wozi_thermostat_2_open_window
            domain: switch
      - conditions:
          - condition: and
            conditions:
              - condition: state
                state: "off"
              - condition: state
                state: "off"
        sequence:
          - type: turn_off
            domain: switch
          - type: turn_off
            domain: switch
          - service: automation.trigger
            data: {}
              entity_id:
                - automation.wozi_openwindow
mode: single
"logbookEntries": [
      "name": "WOZI_openwindow",
      "message": "triggered by state of binary_sensor.schalter_1_contact",
      "source": "state of binary_sensor.schalter_1_contact",
      "entity_id": "automation.wozi_openwindow",
      "context_id": "01GKF6GXSX4PMTBEKRM8VRM7QZ",
      "when": 1670178699.071073,
      "domain": "automation"
      "when": 1670178699.113309,
      "state": "on",
      "entity_id": "switch.wozi_thermostat_1_open_window",
      "context_event_type": "automation_triggered",
      "context_domain": "automation",
      "context_name": "WOZI_openwindow",
      "context_message": "triggered by state of binary_sensor.schalter_1_contact",
      "context_source": "state of binary_sensor.schalter_1_contact",
      "context_entity_id": "automation.wozi_openwindow"
      "when": 1670178699.242274,
      "state": "on",
      "entity_id": "switch.wozi_thermostat_2_open_window",
      "when": 1670178700.037246,
      "state": "off",
I also can’t see an issue here, but I suggest to have a look into the traces of that rule after it has been triggered. You can see both, the wanted and the actual state of entities for example which makes it easier to check what happened.
Maybe this than helps you to find out why it happened.
