Hi everyone!
It seems like a recent update to either OpenWRT or Hass broke my ubus tracker.
Error setting up platform legacy
File "/usr/src/homeassistant/homeassistant/components/device_tracker/setup.py", line 63, in async_setup_legacy
scanner = await hass.async_add_job(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/ubus/device_tracker.py", line 40, in get_scanner
scanner = DnsmasqUbusDeviceScanner(config[DOMAIN])
File "/usr/src/homeassistant/homeassistant/components/ubus/device_tracker.py", line 149, in __init__
super().__init__(config)
File "/usr/src/homeassistant/homeassistant/components/ubus/device_tracker.py", line 85, in __init__
self.session_id = _get_session_id(self.url, self.username, self.password)
File "/usr/src/homeassistant/homeassistant/components/ubus/device_tracker.py", line 247, in _get_session_id
return res["ubus_rpc_session"]
TypeError: 'NoneType' object is not subscriptable
The credentials are correct, the routers have rpcd-mod-file installed, and a user configured in /usr/share/rpcd/acl.d/user.json as per the documentation.
Just to be sure here is the relevant part of my configuration.yaml:
# Presence detection
device_tracker:
- platform: ubus
host: 192.168.0.1
username: !secret openwrt_user
password: !secret openwrt_password
interval_seconds: 10
consider_home: 600
new_device_defaults:
track_new_devices: False
- platform: ubus
host: 192.168.0.5
consider_home: 600
I read in a different topic that I could test the connection with curl but I don’t know what to make of the output:
curl --data-ascii '{"jsonrpc": "2.0", "id": 1, "method": "call", "params": ["00000000000000000000000000000000", "session", "login", {"username": "root", "password": "REDACTED"}]}' http://192.168.0.1/ubus/ -v
* Trying 192.168.0.1...
* TCP_NODELAY set
* Connected to 192.168.0.1 (192.168.0.1) port 80 (#0)
> POST /ubus/ HTTP/1.1
> Host: 192.168.0.1
> User-Agent: curl/7.54.0
> Accept: */*
> Content-Length: 158
> Content-Type: application/x-www-form-urlencoded
* upload completely sent off: 158 out of 158 bytes
< HTTP/1.1 404 Not Found
< Connection: Keep-Alive
< Transfer-Encoding: chunked
< Keep-Alive: timeout=20
< Content-Type: text/html
* Connection #0 to host 192.168.0.1 left intact
Is anyone using OpenWRT 19.07.04 together with Hass 0.116.*?
