I know that there are two integrations for routers running OpenWrt but they are hard to use. I propose new OpenWrt integration for all of us using OpenWrt. If developers could make integrations for ie. alexa or some other devices using cloud then I can strongly believe that OpenWrt integration could be made much much better and easier to use than it is know,
I would like to have integration for OpenWrt that can seamlessly add all routers running OpenWrt with traffic monitoring, connected host, changing wifi channels, turning wifi on/off, monitor channel use etc.
For now situation is that people on their own are making custom integrations to solve some problems because current home assistant integrations are just not good enough.
I know that developers can made some serious integration for OpenWrt routers in home assistant, so please do.
So a third integration would fix what you think is wrong? Seems unlikely.
There are luci and ubus integration. And I tried them both but this is far from seamlessly integrating router in home assistant. As OpenWrt is basically linux distribution I donāt see why shouldnāt there be a OpenWrt package that you can install in OpenWrt that will provide integration to home assistant for ie.
I think that those integrations should be replaced with one but one that will cover it all and will work in gui.
Scratch that itch, go for it. Does openwrt have a rest API?
Yes it does but as I said it is hard to do it. There are some projects that tried to integrate it using rpcd, mqtt, ubus but they are all basically a diecent try to integrate router. You can get some basic stuff but to go a bit deeper its very difficult.
How do you suggest HA should communicate with openwrt then?
It is hard to say for me because Iām not a developer.
There is obviously api documentation. Some guy created some integration based on it but it is hard to use it.
Probably the best way to do it will be using openwrt api.
Hey⦠i am highly interested⦠i am currently playing with openwrt and ubus calls⦠it is not very complicated⦠but some syntaxes are not always seen at the first sightā¦
at the moment i am able to use curl to get for example data of realtimestats of a device⦠or dsl-metricsā¦
what i am not familiar with, is how to use this / integrate this into hassio in a good wayā¦
(just calling a bash schript from an addon, is maybe not the best idea)
for example:
USER="root" # usualy root
PASSW="password"
HOST="http://10.10.10.10"
#getting auth-token into variable
TOKEN=$(curl -sH 'Content-Type: application/json' -d '{ "jsonrpc": "2.0", "id": 1, "method": "call", "params": [ "00000000000000000000000000000000", "session", "login", { "username": '\"$USER\"', "password": '\"$PASSW\"' } ] }' $HOST/ubus | jq -r '.result[1].ubus_rpc_session')
#realtimestats for pppoe-wan
curl -sH 'Content-Type: application/json' -d '{ "jsonrpc": "2.0", "id": 1, "method": "call", "params": [ '\"$TOKEN\"', "luci", "getRealtimeStats", { "mode":"interface","device":"pppoe-wan" } ] }' $HOST/ubus | jq -r '.result[1].result'
#dsl metrics
curl -sH 'Content-Type: application/json' -d '{ "jsonrpc": "2.0", "id": 1, "method": "call", "params": [ '\"$TOKEN\"', "dsl", "metrics", {} ] }' $HOST/ubus | jq -r '.result[1]'
@nickrout
Did you see the authentication method?
it is not HTTP-authā¦
on openwrt ubus calls you have to get a token⦠and then use it in the next call
EDIT:
thx a lot @nickrout
i was able to get deeper into this⦠for example:
command_line:
- sensor:
command: >
curl -sH 'Content-Type: application/json' -d '{ "jsonrpc": "2.0", "id": 1, "method": "call", "params": [ "00000000000000000000000000000000", "session", "login", { "username": "root", "password": "password" } ] }' http://10.10.10.10/ubus
value_template: "{{ value_json.result[1].ubus_rpc_session }}"
scan_interval: 100
- sensor:
command: >
curl -sH 'Content-Type: application/json' -d '{ "jsonrpc": "2.0", "id": 1, "method": "call", "params": [ "{{ states('sensor.randomthing_token') }}", "dsl", "metrics", {} ] }' http://10.10.10.10/ubus | jq '.result[1] | keys'
value_template: "{{ value_json }}"
scan_interval: 3
this is a good start⦠but itās still directly curl
Iām currentyl using collectd with mqtt plugin. Itās oke, it provide some data, but it would be much better if we have one integration that can seamlessly integrate openwrt routers in home assistant. Everything else is just some better or worst individual attempts to make this work.
at first, using mqtt Plugin or maybe node_exporter is a question about push or pullā¦
After some days of research i am not sure if it is easy to have a general implementation⦠it seems, users have very indiviual settings of openwrt.
But i am still interested.
I donāt see why not. People are using various methods because official support is not the best, so to say. Openwrt is a basically a linux distribution and I donāt see a reason why not to have a good integration. As I saw there is api now. And Iām pretty sure that openwrt integration could be much much better than it is today.
Writing about this, just cross my mind. We could probably use ssh integration and combine that with other stuff.
But again, this is just individual attemps to solve this problem.
Openwrt using ssh integration, defaults
Still no āintegrationā⦠but i was playing with this to understand it and to get a resultā¦
Just for your information⦠this works with āHA-Multiscrapeā:
configuration.yaml:
command_line:
- sensor:
name: "OpenWRT ubus Sessiontoken"
command: >
curl -sH 'Content-Type: application/json' -d '{ "jsonrpc": "2.0", "id": 1, "method": "call", "params": [ "00000000000000000000000000000000", "session", "login", { "username": "root", "password": "pass" } ] }' http://10.10.10.10/ubus
scan_interval: 200
multiscrape:
- name: "Multiscrape DSL"
resource: http://10.10.10.10/ubus
method: POST
headers:
payload: '{ "jsonrpc": "2.0", "id": 1, "method": "call", "params": [ "{{ states("sensor.openwrt_ubus_sessiontoken") }}", "dsl", "metrics", {} ] }'
scan_interval: 5
verify_ssl: false
log_response: true
- unique_id: dsl_atuc_vendor_id
name: ATU-C System Vendor ID
value_template: '{{ value_json.result[1].atu_c.vendor }}'
- unique_id: dsl_chipset
value_template: '{{ value_json.result[1].chipset }}'
- unique_id: dsl_firmware_version
name: Modem Firmware Version
value_template: '{{ value_json.result[1].firmware_version }}'
- unique_id: dsl_api_version
name: Modem Api Version
value_template: '{{ value_json.result[1].api_version }}'
- unique_id: dsl_annex_s
value_template: '{{ value_json.result[1].annex }}'
- unique_id: dsl_line_mode_s
name: DSL Line Mode
value_template: '{{ value_json.result[1].mode }}'
- unique_id: dsl_profile_s
value_template: '{{ value_json.result[1].standard }}'
- unique_id: dsl_line_state_num
name: DSL Line State
value_template: '{{ value_json.result[1].state_num }}'
- unique_id: dsl_line_state_detail
name: DSL Line State detail
value_template: '{{ value_json.result[1].state }}'
name: DSL Line Status
value_template: '{{ value_json.result[1].up }}'
- unique_id: dsl_power_mode_s
name: Power Management Mode
value_template: '{{ value_json.result[1].power_state }}'
- unique_id: dsl_data_rate_down
name: Data Rate Down
unit_of_measurement: Mbit
value_template: '{{ value_json.result[1].downstream.data_rate / 1000000 }}'
- unique_id: dsl_data_rate_up
name: Data Rate Up
value_template: '{{ value_json.result[1].upstream.data_rate / 1000000}}'
- unique_id: dsl_line_attenuation_down
name: Line Attenuation (LATN) down
unit_of_measurement: dB
value_template: '{{ value_json.result[1].downstream.latn }}'
- unique_id: dsl_line_attenuation_up
name: Line Attenuation (LATN) up
value_template: '{{ value_json.result[1].upstream.latn }}'
- unique_id: dsl_noise_margin_down
name: Noise Margin (SNR) down
value_template: '{{ value_json.result[1].downstream.snr }}'
- unique_id: dsl_noise_margin_up
name: Noise Margin (SNR) up
value_template: '{{ value_json.result[1].upstream.snr }}'
- unique_id: dsl_signal_attenuation_down
name: Signal Attenuation (SATN) down
value_template: '{{ value_json.result[1].downstream.satn }}'
- unique_id: dsl_signal_attenuation_up
name: Signal Attenuation (SATN) up
value_template: '{{ value_json.result[1].upstream.satn }}'
- unique_id: dsl_actatp_down
name: Aggregate Transmit Power(ACTATP) down
value_template: '{{ value_json.result[1].downstream.actatp }}'
- unique_id: dsl_actatp_up
name: Aggregate Transmit Power(ACTATP) up
value_template: '{{ value_json.result[1].upstream.actatp }}'
- unique_id: dsl_max_data_rate_down
name: Max. Attainable Data Rate (ATTNDR) down
value_template: '{{ value_json.result[1].downstream.attndr / 1000000 }}'
- unique_id: dsl_max_data_rate_up
name: Max. Attainable Data Rate (ATTNDR) up
value_template: '{{ value_json.result[1].upstream.attndr / 1000000 }}'
- unique_id: dsl_line_uptime
unit_of_measurement: s
value_template: '{{ value_json.result[1].uptime }}'
- unique_id: dsl_errors_fec_near
name: Forward Error Correction Seconds (FECS) near
value_template: '{{ value_json.result[1].errors.near.fecs }}'
- unique_id: dsl_errors_fec_far
name: Forward Error Correction Seconds (FECS) far
value_template: '{{ value_json.result[1].errors.far.fecs }}'
- unique_id: dsl_errors_es_near
name: Errored seconds (ES) near
value_template: '{{ value_json.result[1].errors.near.es }}'
- unique_id: dsl_errors_es_far
name: Errored seconds (ES) far
value_template: '{{ value_json.result[1].errors.far.es }}'
- unique_id: dsl_errors_ses_near
name: Severely Errored Seconds (SES) near
value_template: '{{ value_json.result[1].errors.near.ses }}'
- unique_id: dsl_errors_ses_far
name: Severely Errored Seconds (SES) far
value_template: '{{ value_json.result[1].errors.far.ses }}'
- unique_id: dsl_errors_loss_near
name: Loss of Signal Seconds (LOSS) near
value_template: '{{ value_json.result[1].errors.near.loss }}'
- unique_id: dsl_errors_loss_far
name: Loss of Signal Seconds (LOSS) far
value_template: '{{ value_json.result[1].errors.far.loss }}'
- unique_id: dsl_errors_uas_near
name: Unavailable Seconds (UAS) near
value_template: '{{ value_json.result[1].errors.near.uas }}'
- unique_id: dsl_errors_uas_far
name: Unavailable Seconds (UAS) far
value_template: '{{ value_json.result[1].errors.far.uas }}'
- unique_id: dsl_errors_hec_near
name: Header Error Code Errors (HEC) near
value_template: '{{ value_json.result[1].errors.near.hec }}'
- unique_id: dsl_errors_hec_far
name: Header Error Code Errors (HEC) far
value_template: '{{ value_json.result[1].errors.far.hec }}'
- unique_id: dsl_errors_crc_p_near
name: Non Pre-emtive CRC errors (CRC_P) near
value_template: '{{ value_json.result[1].errors.near.crc_p }}'
- unique_id: dsl_errors_crc_p_far
name: Non Pre-emtive CRC errors (CRC_P) far
value_template: '{{ value_json.result[1].errors.far.crc_p }}'
- unique_id: dsl_errors_crcp_p_near
name: Pre-emtive CRC errors (CRCP_P) near
value_template: '{{ value_json.result[1].errors.near.crcp_p }}'
- unique_id: dsl_errors_crcp_p_far
name: Pre-emtive CRC errors (CRCP_P) far
value_template: '{{ value_json.result[1].errors.far.crcp_p }}'
- unique_id: dsl_errors.near.rx_corrupted
value_template: '{{ value_json.result[1].errors.near.rx_corrupted }}'
- unique_id: dsl_errors.far.rx_corrupted
value_template: '{{ value_json.result[1].errors.far.rx_corrupted }}'
- unique_id: dsl_errors.near.rx_uncorrected_protected
value_template: '{{ value_json.result[1].errors.near.rx_uncorrected_protected }}'
- unique_id: dsl_errors.far.rx_uncorrected_protected
value_template: '{{ value_json.result[1].errors.far.rx_uncorrected_protected }}'
- unique_id: dsl_errors.near.rx_retransmitted
value_template: '{{ value_json.result[1].errors.near.rx_retransmitted }}'
- unique_id: dsl_errors.far.rx_retransmitted
value_template: '{{ value_json.result[1].errors.far.rx_retransmitted }}'
- unique_id: dsl_errors.near.rx_corrected
value_template: '{{ value_json.result[1].errors.near.rx_corrected }}'
- unique_id: dsl_errors.far.rx_corrected
value_template: '{{ value_json.result[1].errors.far.rx_corrected }}'
- unique_id: dsl_errors.near.tx_retransmitted
value_template: '{{ value_json.result[1].errors.near.tx_retransmitted }}'
- unique_id: dsl_errors.far.tx_retransmitted
value_template: '{{ value_json.result[1].errors.far.tx_retransmitted }}'
since i never coded with python, it will take a while to understand and to work on an integration⦠if anyone starts-up, i will try my best to contributeā¦
I am wondering what exactly is wrong with the rest integration for you. You could have what you want set up by now if you stopped moaning and got in with it.
- i am not moaning⦠i am on a learning-path with experimentsā¦
- i gave it a try⦠but was not able to realise a single curl-command to get the whole json string to work with⦠it is too big and results in an error about complaining it has more than 255 characters:
This:
- sensor:
command: >
curl -sH 'Content-Type: application/json' -d '{ "jsonrpc": "2.0", "id": 1, "method": "call", "params": [ "{{ states('sensor.randomthing_token') }}", "dsl", "metrics", {} ] }' http://10.10.10.10/ubus | jq '.result[1]'
scan_interval: 3
results into this:
2024-06-07 20:49:11.203 ERROR (MainThread) [homeassistant.helpers.entity] Failed to set state for sensor.randomthing_sensor, fall back to unknown
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1198, in _async_write_ha_state
hass.states.async_set(
File "/usr/src/homeassistant/homeassistant/core.py", line 2313, in async_set
state = State(
File "/usr/src/homeassistant/homeassistant/core.py", line 1786, in __init__
validate_state(state)
File "/usr/src/homeassistant/homeassistant/core.py", line 223, in validate_state
raise InvalidStateError(
homeassistant.exceptions.InvalidStateError: Invalid state with length 2610. State max length is 255 characters.
My response wasnāt to you.
Try restful though.
I coudnāt implement first step in ha, use token and when it expires renew it and get data from router using that token.
So I went with collectd + mqtt that was easier for me and my knowledge level to implement. So I did that. I got couple of dozen sensors for each router. And Iām using ssh integration for all routers. But this is not done, as I would like to get some more out of it and that requires time and effort to do it.
In the end of the day everything comes back to one - if you want something done, do it yourself.
Just found this⦠maybe a good start:
I tried that but I just got a few sensors. I never managed to go any further and get some more sensors. This integration has one problem. It became unavailable if there are no devices connected to wifi. This was reported but never fixed. It looks promising but guy that initially made this integration doesnt have time or will to deal with all bugs and improvements.
For me the best solution is still using collectd + mqtt and send data to home assistant.
Iām using separate file for mqtt sensors in configuration.yaml like this
mqtt: !include mqtt_sensor.yaml
I created file mqtt_sensor.yaml and create some sensor for it like this
### Openwrt config
- name: OpenWrt RAM buffered
state_topic: "collectd/OpenWrt/memory/memory-buffered"
unit_of_measurement: MB
value_template: "{{ value.split(':')[1].split('\x00')[0] | float / 1000000 }}"
unique_id: ram_buffered
- name: OpenWrt RAM free
state_topic: "collectd/OpenWrt/memory/memory-free"
unique_id: ram_free
- name: OpenWrt RAM cached
state_topic: "collectd/OpenWrt/memory/memory-cached"
unique_id: ram_cached
- name: OpenWrt RAM used
state_topic: "collectd/OpenWrt/memory/memory-used"
unique_id: ram_used
# AP 2.4 Ghz
- name: "OpenWrt 2.4 Bitrate"
state_topic: "collectd/OpenWrt/iwinfo-phy0-ap0/bitrate"
unit_of_measurement: "Mbps"
unique_id: "OpenWrt_2.4_bitrate"
- name: "OpenWrt 2.4 Signal Power"
state_topic: "collectd/OpenWrt/iwinfo-phy0-ap0/signal_power"
unit_of_measurement: "dBm"
value_template: "{{ value.split(':')[1].split('\x00')[0] }}"
unique_id: "OpenWrt_2.4_signal_power"
- name: "OpenWrt 2.4 Signal Noise"
state_topic: "collectd/OpenWrt/iwinfo-phy0-ap0/signal_noise"
unique_id: "OpenWrt_2.4_signal_noise"
- name: "OpenWrt 2.4 Signal Quality"
state_topic: "collectd/OpenWrt/iwinfo-phy0-ap0/signal_quality"
unit_of_measurement: "dB"
unique_id: "OpenWrt_2.4_signal_quality"
- name: "OpenWrt 2.4 Stations"
state_topic: "collectd/OpenWrt/iwinfo-phy0-ap0/stations"
unit_of_measurement: "stations"
unique_id: "OpenWrt_2.4_stations"
# AP 5 Ghz
- name: "OpenWrt 5 Bitrate"
state_topic: "collectd/OpenWrt/iwinfo-phy1-ap0/bitrate"
unique_id: "OpenWrt_5_bitrate"
- name: "OpenWrt 5 Signal Power"
state_topic: "collectd/OpenWrt/iwinfo-phy1-ap0/signal_power"
unique_id: "OpenWrt_5_signal_power"
- name: "OpenWrt 5 Signal Noise"
state_topic: "collectd/OpenWrt/iwinfo-phy1-ap0/signal_noise"
unique_id: "OpenWrt_5_signal_noise"
- name: "OpenWrt 5 Signal Quality"
state_topic: "collectd/OpenWrt/iwinfo-phy1-ap0/signal_quality"
unique_id: "OpenWrt_5_signal_quality"
- name: "OpenWrt 5 Stations"
state_topic: "collectd/OpenWrt/iwinfo-phy1-ap0/stations"
unique_id: "OpenWrt_5_stations"
# Data
- name: OpenWrt Network traffic out
state_topic: "collectd/OpenWrt/interface-br-lan/if_octets"
value_template: "{{ value.split(':')[1].split('\x00')[0] | float / 10000 }}"
unique_id: openwrt_network_traffic_out
- name: OpenWrt Network traffic in
value_template: "{{ value.split(':')[2].split('\x00')[0] | float / 10000 }}"
unique_id: openwrt_network_traffic_in
# Uptime
- name: "OpenWrt uptime"
state_topic: "collectd/OpenWrt/uptime/uptime"
value_template: >
{% set uptime_seconds = value.split(':')[1].split('\x00')[0] | float %}
{% set uptime_minutes = uptime_seconds / 60 %}
{% set uptime_hours = uptime_seconds / 3600 %}
{% if uptime_minutes < 60 %}
{{ uptime_minutes | round(0) }} min
{% elif uptime_hours < 24 %}
{{ uptime_hours | round(2) }} hr
{% else %}
{{ (uptime_seconds / 86400) | round(2) }} days
{% endif %}
unique_id: "OpenWrt_uptime"
For others dumb aps sensors are basically copy/paste with different topics.
You can just reload manully created mqtt entities and they will appear in home assistant. There is no need for ha restart.
There are more sensor to add in home assistant and all can be checked out using mqtt explorer.
Using ssh integration you can get list connected devices using
service: ssh.execute_command
command: ip neigh
but currently the problem is how to integrate or create sensors from received data or just integrate it in some lovelace dashboard that will display connected devices, ip address, lease time, online, offline etc.
After a while and using ai to write correct file, there it is. It is still a working version but itās working.
Ssh to your router
Create a file connected_devices.sh. I created it in /etc directory and add to it
#!/bin/sh
BROKER="Ip_ha_broker"
PORT="1883"
USER="mqtt"
PASSWORD="mqtt_password"
BASE_TOPIC="collectd/OpenWrt/devices"
DISCOVERY_PREFIX="homeassistant"
NODE_ID="openwrt"
for device in $(cat /proc/net/arp | grep -v "IP address" | awk '{print $1}'); do
# Generate the topic for the device
DEVICE_TOPIC="${BASE_TOPIC}/device_${device}"
# Generate unique ID for the device
DEVICE_ID=$(echo $device | tr '.' '_')
# Remove leading zeros from DEVICE_ID for cleaner formatting
DEVICE_ID=$(echo $DEVICE_ID | sed 's/^0*//')
# Generate the payload for the device
PAYLOAD="{\"connected_device\": \"online\"}"
# Publish the payload to the MQTT broker
mosquitto_pub -h $BROKER -p $PORT -u $USER -P $PASSWORD -t $DEVICE_TOPIC -m "$PAYLOAD"
# Publish online status
mosquitto_pub -h $BROKER -p $PORT -u $USER -P $PASSWORD -t "${DEVICE_TOPIC}/status" -m "online"
# Generate sanitized unique ID for the device in Home Assistant
UNIQUE_ID="${NODE_ID}_${DEVICE_ID}"
# Publish discovery message for the sensor
DISCOVERY_TOPIC="${DISCOVERY_PREFIX}/sensor/${NODE_ID}/${DEVICE_ID}/config"
DISCOVERY_PAYLOAD="{
\"name\": \"Device ${device}\",
\"state_topic\": \"${DEVICE_TOPIC}\",
\"value_template\": \"{{ value_json.connected_device | default('offline') }}\",
\"availability_topic\": \"${DEVICE_TOPIC}/status\",
\"payload_available\": \"online\",
\"payload_not_available\": \"offline\",
\"unique_id\": \"${UNIQUE_ID}\",
\"device\": {
\"identifiers\": [\"${UNIQUE_ID}\"],
\"model\": \"Generic Device\",
\"manufacturer\": \"Your Manufacturer\"
mosquitto_pub -h $BROKER -p $PORT -u $USER -P $PASSWORD -t "$DISCOVERY_TOPIC" -m "$DISCOVERY_PAYLOAD"
# Print a message indicating the payload has been published
echo "Published payload: $PAYLOAD to topic: $DEVICE_TOPIC"
echo "Published discovery message to topic: $DISCOVERY_TOPIC"
done
Donāt forget to make it exec, i done chmod 755 connected_devices.sh
Edit crontab file with
crontab -e
and add
* * * * * /etc/connected_devices.sh
And have to install mosquitto client for this to work.
And it is working for now. It will create mqtt devices in home assistant and show if device is online or offline. Its not perfect, it is build with ai but it is simple and it is working.
