OpenWRT Monitor
I had an issue with OpenWRT. The problem ended up being in a strange one-off configuration item I made. But the data collection in the process of debugging it was pretty useful (I think). So I’m going to take a few minutes to share the process. This could be useful for many routers or server monitors.
Firstly, these were my goals:
  • I don’t want HA to have my router password. HA might be more secure than my personal computer, but it feels weird to have the server know the passwords or have ssh keys for other servers.
  • I want to read basic information, like uptime, load, and memory usage from the router.
  • My setup has two OpenWRT routers and I have a Linux machine as my daily driver.
Main Script:
The big idea is to use hass-cli to publish a state value that I get from an automatic ssh command from a Linux machine to the router. This script does these things:
  1. ssh’es into the router
  2. Runs a diagnostic command, like uptime.
  3. Uses python to parse the response from that command to extract the number.
  4. Uses hass-cli to publish that state to an input number value in home assistant.
openwrt-stats.sh:
#!/usr/bin/env bash
export HASS_SERVER=http://X.X.X.X:8123
export HASS_TOKEN=redacted
PATH=/home/jeffeb3/.local/bin:$PATH
UPTIME_TEXT=`ssh [email protected] uptime`
UPTIME=`echo $UPTIME_TEXT | /home/jeffeb3/src/openwrt-hass/uptime_to_minutes.py`
hass-cli service call input_number.set_value --arguments entity_id=input_number.openwrt_downstairs_uptime,value=$UPTIME
This is a bash script. Before you run this, you should be able to do ssh root@router-ip uptime and get a response like: 13:49:27 up 1 day, 5:25, load average: 0.32, 0.28, 0.25. The UPTIME_TEXT is set to that result and passed to the uptime_to_minutes.py script, which returns a number of minutes.
The python script will get that text in stdin and parse it for the uptime and convert it to an integer amount of minutes.
uptime_to_minutes.py:
#!/usr/bin/env python3
import sys
def getMinsFromTime(number, unit):
    if unit == 'min,':
        return int(number)
    else:
        hours, minutes = [int(x.strip(',')) for x in number.split(':')]
        return hours * 60 + minutes
def getMins(words):
    if words[3] == 'day,' or words[3] == 'days,':
        days = int(words[2])
        mins = days * 24 * 60 + getMinsFromTime(words[4], words[5])
    else:
        mins = getMinsFromTime(words[2], words[3])
    return mins
for line in sys.stdin:
    words = line.strip().split()
    if len(sys.argv) == 1:
        print(getMins(words))
Then that returns to the bash script. The hass-cli line pushes that integer number of minutes to home assistant in the state: input_number.openwrt_downstairs_uptime. You have to make that input number first as a helper in the settings.
I would really like some of the stats from the router to be available without root permissions. Ideally, as a public facing json object. Using python requests to grab the stats directly from home assistant without giving home assistant credentials to my router would be awesome. But this worked for the issue I was trying to debug. YMMV.
So… you’re reinventing SNMP? Something that’s been around since 1988, supports Read-Only credentials and is supported by HA and a majority of network equipment?
“Reinventing Standards” was my nickname in high school!
Joking aside, I didn’t think SNMP did this. I will have to look into it. Thanks for the tip. (Maybe be less snarky next time though).
Lol, fair enough. :wink: Usually devices/software have a published MIB detailing what stats are available. Some are quite detailed. There are also many utilities for browsing the available data.
@jeffeb3
take a look at node_exporter packages for openwrt… i am currently also playing with it
How do you set up SNMP with OpenWRT for Home Assistant?
Mine’s connecting to my phone’s hotspot over Wi-Fi and outputting that over LAN to my router’s WAN2.
All I wanna know is:
  1. Is it running?
  2. Is it connecting to my phone when hotspot is enabled?
  3. The version of OpenWRT (so I can get a warning or notification if a new version is out).
Unfortunately I’m not an OpenWRT user, so I couldn’t say.
Sorry for the late response, I arrived here looking for ways to monitor my OpenWRT.
Why not use something like a Prometheus exporter prometheus-node-exporter-lua
e.g. this looks like a comprehensive tutorial of how to set this up using Grafana’s free tier but once the agent is installed on the monitored router, I expect it’s possible to monitor it with Prometheus - Home Assistant
Personally, I’m in two minds because I’d like visibility into my router also if and when it’s down - I might end up monitoring it both from HA and an external service as described in the link above.
I use collectd to import my OpenWRT data (uptime, load values, ram usage, etc) into Home Assistant using MQTT. It requires a file on the OpenWRT device with your MQTT broker info and it pulls whatever data you want into a mqtt sensor. I use the ping integration to keep track of connectivity.
I do use the ssh commands with secure keys with home assistant cli to control my access points. This allows me to restart interfaces or wifi radios, turn on/off interfaces or wifi radios, restart services like dnsmasq or odhcpd, and reboot my access points.
I’m sorry but the HA Prometheus integration is also an exporter only, so cannot ingest data as sensors. There is however a Prometheus Sensor HACS integration you can try.
I also use the uPnP/IGD integration to monitor my router and internet connectivity (you can configure OpenWrt to use uPnP more securely than other routers).
Wouldn’t be just nice to have Openwrt integration in home assistant?
I think it would.
@ddaniel there is an openwrt integration, but it seems, that it needs a lot of love :smiling_face_with_tear:
Because it was simpler for me, i develop in the last days a little addon, which collects data from an openwrt router and sends it via mqtt to HA.
At this moment i collect basic router informations, wifi networks and the connected devices by network (and switch the devices between 2.4 ↔ 5 GHz networks, if they switch at openwrt).
But i forgot about load and mem :sweat_smile: i think i will add this after eastern
Thank you for your effort.
Unfortunately I don’t use haos. I’m using ha in container and I can’t use this.
Unless there will be a docker version of it.
But I think this is probably good way to start.
i see, that’s a problem :confused: do you need normal docker images, or can you run ha addons if they are prebuild? (i never tested HA in docker :sweat_smile: )
I use docker images with docker compose.
I believe that you can’t run ha addons in container installation as addons are just docker containers.
