I’m trying to upgrade the OZW addon to 0.5.3 from 0.5.2 and run into the following issue. Currently on HA 114.4 on a RPi 4.
20-09-15 02:01:16 INFO (SyncWorker_0) [supervisor.docker.interface] Pull image homeassistant/armv7-addon-zwave tag 0.5.3.
20-09-15 02:01:21 ERROR (SyncWorker_0) [supervisor.docker.interface] Can’t install homeassistant/armv7-addon-zwave:0.5.3 -> 404 Client Error: Not Found (“manifest for homeassistant/armv7-addon-zwave:0.5.3 not found: manifest unknown: manifest unknown”).
20-09-15 02:01:21 INFO (SyncWorker_0) [supervisor.docker.interface] This error is often caused by not having enough disk space available. Available space in /data is: 48.9 GiB
I know that my SD card has plenty of space for the upgrade so not sure why it is throwing this error.
I’m also having issues - update just won’t work. Can’t find appropriate section in the logs. Raspberry Pi 3b+, latest Home Assistant build, currently on OZW 0.5.2
