Openzwave 0.7.0 update
Anyone dare to update yet?
How went it?
I did the update, and didn’t have any noticeable issues. Just be patient as it comes back up.
I have 34 devices on my ZWave network, and needed this update so I could use an older Leviton plug again. Everything seems to be working as expected so far.
Did it, couldn’t resist… so far so good… not seeing any visible changes.
I also upgraded and can see one improvement - it seems to remember the Network Object Cache setting (I was having to increase it from 1,000 to 1,500 every time I used the qt thing). The other things that didn’t work are still not working :slight_smile:
Hold before you update, the old issue is back:
[20201121 11:07:28.110 CET] [ozw.logging] [debug]: popping Log Mesages
[20201121 11:07:28.114 CET] [ozw.library] [critical]: Error - Node: 0 ERROR: Not enough space in stream buffer
[20201121 11:07:28.114 CET] [ozw.logging] [debug]: popping Log Mesages
[20201121 11:07:29.110 CET] [ozw.library] [critical]: Error - Node: 0 ERROR: Not enough space in stream buffer
[20201121 11:07:29.110 CET] [ozw.logging] [debug]: popping Log Mesages
[20201121 11:07:29.114 CET] [ozw.library] [critical]: Error - Node: 0 ERROR: Not enough space in stream buffer
[20201121 11:07:29.114 CET] [ozw.logging] [debug]: popping Log Mesages
[20201121 11:07:30.110 CET] [ozw.library] [critical]: Error - Node: 0 ERROR: Not enough space in stream buffer
[20201121 11:07:30.110 CET] [ozw.logging] [debug]: popping Log Mesages
[20201121 11:07:30.114 CET] [ozw.library] [critical]: Error - Node: 0 ERROR: Not enough space in stream buffer
[20201121 11:07:30.114 CET] [ozw.logging] [debug]: popping Log Mesages
[20201121 11:07:31.110 CET] [ozw.library] [critical]: Error - Node: 0 ERROR: Not enough space in stream buffer
[20201121 11:07:31.110 CET] [ozw.logging] [debug]: popping Log Mesages
[20201121 11:07:31.116 CET] [ozw.library] [critical]: Error - Node: 0 ERROR: Not enough space in stream buffer
[20201121 11:07:31.116 CET] [ozw.logging] [debug]: popping Log Mesages
[20201121 11:07:32.110 CET] [ozw.library] [critical]: Error - Node: 0 ERROR: Not enough space in stream buffer
[20201121 11:07:32.110 CET] [ozw.logging] [debug]: popping Log Mesages
[20201121 11:07:32.115 CET] [ozw.library] [critical]: Error - Node: 0 ERROR: Not enough space in stream buffer
[20201121 11:07:32.115 CET] [ozw.logging] [debug]: popping Log Mesages
Yes, initially worked but dead after a restart, ozwadmin app would not connect either… reverting to snapshot…
Been a few days - how are things now? 0.7.1 is out but I’m still reluctant to update considering the issues I had getting to 0.5.
No issues with 0.7.1. Only “overall” issue that it hangs sometimes, but that was also in 0.5.0… (for me).
0.7.1 has been running ok for me for the past week. Only got six z-wave plus devices running so far (fibaro switches, motion sensors and door sensors).
