I then look into the openzwave control panel and see for my aeotec z-stick gen5 controller I see that the “security network key” is 0.
The security network is disabled.
I would expect that would mean the S2 capability? and should be enabled? Also I would expect that the network key in the add-on should be the one in the “security network key”
Thats something completely different…
You may be able to see it under File -> Configuration -> OpenZWave -> NetworkKey (not sure if it propagates from the docker environment TBH though)
I didn’t have any part in the HA addon, just the integration. I believe Frenck and pvizeli have been working on the official addon, and @marcelveldt did the unofficial/beta addon.
Just for my clarity sake - Your confirming in ozwadmin the Network Key is showing right? How are you setting it, via a Environment Variable or Docker Secret?
