OpenZwave addon: ZME_WCD2
It seems like openzwave is not sending anything related to this device further to mqtt (the OpenZwave topic). I do see response in the VNC Openzwave management interface.
Included (insecure because secure wasn’t working) the following device successfully. A "ZME_WCD2 Double Paddle Wall Controller:
It shows button pressed on the OZW control panel via VNC. But no output is seen in home assistant and/or in MQTT (Using MQTT explorer I see nothing happen on any button presses but I do see on the VNC viewer…)
I really hope I am missing something very simple because this is the first of many I am wanting to migrate from Vera.
I have also tried other “Action on Group x” settings (and yes I know how to wake the device etc.)
I can see direct action in the “Event List” upon button presses. But nothing in home assistant… (also not in Node Red via the events:all node and also not in mqtt explorer…
help :confounded:
This must have to do with it:
And this is the manual:
Basic Set is not supported in the new integration. Try changing the “Action on Group” settings to Send Scenes or Send Preconfigured Scenes. You will probably need to add Node 1 (controller) as an association for groups 2-4. If the scenes are being sent, you can detect them with the ozw.scene_activated Event.
Thank you for your response, I will try tomorrow!
Think I tried all flavours on all 4 “Action on group” settings. How can I add node 1 as an association group?
Group 1 is already associated by default. If you set the Group 1 setting to one of the Scene values, do you have any different behavior? In HA you can go to Dev Tools -> Events and listen to even ozw.scene_activated.
For the other groups you’ll have to use an MQTT command for now. MQTT Explorer is a good program to use.
Publish a message with topic OpenZWave/1/command/addassociation/. The message payload would be something like this to assign Group 2.
  "node": <node number>,
  "group": 2,
  "target": "1.0"
Replace with the integer value of your node.
Will try. But is it correct I currently see NOTHING on any button press in mqtt explorer?
If it’s a basic set value, you won’t see anything.
Hi, OK I think I am lost…
have tried (a lot) but nothing gives me any outputs in the ozw.scene_activated for this device. I have node-red open listen and debugging everything on this and for this device it is silent (for another scene controller it works). I do only see “things happen” in the VNC window. Nothing coming in MQTT (and thus home assistant).
I have added that association, but not sure what this does on the openzwave part since nothing is coming in on mqtt from this device at all (!).
some screenshots:
These setting give me output above (see in screenshot)
the settings no output at all (nothing in zwave)
Adding this for node 6: OpenZwave addon: ZME_WCD2
Added for node 6 but nothing happens…
Hi, another update. After restarting (hass) mqtt was empty. I added again:
But I do not get the wall-c to send “any” command to hass. I do see however something in ozwadmin. But nothing goes to MQTT or hass…
Hi, did you ever get it to work @sender. I’m facing the same problem as you.
Nope, disposed the thing
